Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Flicker then display goes black
Samsung syncmaster 22 inch flickers then display shuts off. power is still on but display is black
  • ronf6 May 24, 2009
    Its plugged up through dvi and when i push power button the image appears on screen very darkly. It flickers fro a minute or two and then it goes black but the power light remains on.
  • Frank Zhang
    Frank Zhang May 11, 2010
    plug out VGA cable then turn it on, still flickers then dark and power lights on?
  • 191 Answers
Your monitor got trouble at:
1) monitor inverter board components fail like capacitor or MOSFET diver, it can repair or change this parts to fix.
2) there is disconnection between the inverter and CCFL lamps
need to check by technician, it could be fixed,
3) check the DCpower supply board capacitors swelling which need to reaplace, and fix it.
all steps need to do and fix it well.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 24, 2009
    Problem Solver:
  • 7 Answers
My samsung syncmaster 225bw when turned on would have the back light stay on for about one second, then go black, with or without the signal cable attached to the computer. After your screen goes black, shine a flash light on the screen to see if you can see any images
I repaired my monitor by replacing several bad electrolitic capacitors on the inverter board. These capacitors had broken bulging leaking vents on ther tops. There were two 820uf 25v and one 330uf 25v electrolitic capacitors that had failed. I ordered from www.digikey.com Panasonic FC series low impedance electrolitic capacitors, However, the 820uf was not curently stocked and had to be backordered, so I got one 1000uf and one 680uf to replace the two 820uf which were in parallel on the board. There were two 680uf 25v on my board which had not yet failed, so I also replaced them. On my monitor, the capacitors can not be longer than 20mm, due to space limitations. These electrolitic capacitors have a life time between 1000 to 5000 hours, so when you order get a few extra of the ones that went bad.
Posted on Jun 23, 2009
Hi, I have Samsung Syncmaster 226cw monitor. When i turn it on the screen flickers then goes black. If i do this a few times it sorts itself out. During the flickering there is a high pitch buzzing...
I have the identical model with the same problem, I pulled it apart and the power supply/inverter board are one, and descovered the problem was in the inverter transformers, { 2 in all } because my monitor is 3 to 5 years old I felt replacing the whole board assembly would not justify the cost since something else could break down, I opted for a new monitor.
Sep 15, 2011 | Samsung SyncMaster 226CW 22" Monitor
I have a SyncMaster 510N, where i find flickering problem. But display is okay. I difficult to view the screen. Is this major issue?
power cable and data cable connection may be loose
tight it
2. your wall socket of power may not having earth connection properly
Sep 08, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
My Samsung SyncMaster 226CW flickered and then shut off...it will not turn on anymore. anything i can do here to avoid buying another.
yes reove rear cover. look at power supply for crowned or leaking capacitors. desolder . take bad ones to electronics parts store, replace and good to go
Dec 26, 2009 | Samsung SyncMaster 226CW 22" Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Syncmaster 226CW showing picture only for a second + flickering
Call and get the RMA for your monitor, the problem is in the power supply and it will only get worse. This is a common problem with LCD monitors after 2-3 years of use.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
3,077 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
