Question about Breville BKC600XL Coffee Maker
Keurig brewer turned off and it won't turn back on.
It is plugged into a live outlet and still won't work.
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
Keurig won t turn on
This is a known problem with the Keurig and is actually addressed on their website. Problem With Your Keurig Coffee Brewer
http://www.keurigtroubleshooting.com/Keurig-Coffee-Brewer-Problems.html
Jan 04, 2014 | Coffee Makers & Espresso Machines
My B40 Elite Brewer will not start. It had been running fine, then the blue light goes off and now it won't start again. Have changed outlets and still nothing.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 17, 2011 | Keurig Elite B40 Coffee Maker
My keurig won't even turn on. We unplugged and replugged but still nothing. The outlet does work, so don't know what to do. Is there a fuse or something simple that I could try. The Keurig is about...
heatman101
Aug 13, 2011 | Keurig B60 Coffee Maker
The machine won't turn on at all. Tried t in several functioning outlets and it won't power up. Only 6 months old. Keurig B60
heatman101
Aug 11, 2011 | Keurig B60 Coffee Maker
I turned my Keurig off when I went to work yesterday, and now the power won't go back on. It's not the outlet.
heatman101
Aug 09, 2011 | Keurig Platinum B70 Coffee Maker
I bought a new keurig and the unit has been plugged in for 20 minutes and says its not ready...I've turned it off for 30 sec. and turned it back on and still says not ready..any suggestions?
Slam the tank down.. the pump is not priming...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 27, 2011 | Keurig B70 Coffee Maker
Breville BKC600XL Coffee Maker Logo
186 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
