Question about Intel D865PERL Motherboard
D865PERL Motherboard over heating
After 2 years the system is overheating and shutting down while trying to reboot it appears to be the cpu over heating however i have replaced the cpu with a known good one  and it still does the same thing  any help
thanks
garry hixson
  • ghixson Oct 20, 2007
    the motherboard is aD865PERL the cpu is standard boxed  3.00
  • 3 Answers
I had a problem with my P4 overheating on that same board, I cleaned all the dust out of the heat sink and the coolant fan, then also angled another fan at 45 degree from the back to the CPU sounds like alot, but worked for me.
probly just ganna be a hastle so unless you think a fan would help dont bother
Posted on Nov 27, 2007
  • XintelX Nov 27, 2007
    oh also check your Cpu fanspeed
SOURCE:
Hp pavavillion dv6 overheating issue
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Use Additional Cooling Units
Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher to maintain your system performance
Sep 15, 2013 | HP 417136-001 PAVILLION DV8000 MOTHERBOARD
For a week now my laptop has been overheating,then will shut itself down,the overheating happens rapidly,all internet connections have slowed exponentiallyy as a result,is it fan related?the laptop is
The laptop will need to be dismantled down to the motherboard level, use a can of compressed air attach straw and blow out all ports, heatsink and fan. It might be a good idea to remove both for closer inspection and several good blast of air for good measure, and check the thermal paste between the heatsink and processor ic has not dried out.
Apr 09, 2012 | Compaq Presario CQ62-112TU
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Computer shuts down by itself
There can be many reasons of unexpected shut down of your system.Below are some remedies to solve it
Run an anti-spy ware and anti-virus utility to make sure that the shutdowns aren't being caused by a malicious program. If the shutdowns are infrequent, install a CPU temperature monitor utility to keep track of the CPU's temperature. If the CPU is overheating, or the shutdowns are frequent, then you will need to troubleshoot your computer's internal components.
Check any recently installed internal components to ensure that they are properly connected to the computer's motherboard. Make sure any new expansion cards or memory modules are securely seated in their slots, and ensure that the power and data cables are properly connected to any new drives.
Check for large dust buildups on your CPU fan. If the fan isn't effectively cooling your CPU, the overheating CPU will cause your computer to power off. Carefully pick away large pieces of dust with your fingers, and then spray the CPU fan with a can of compressed air to remove the rest of the dust.
Reapply the heat sink compound between the CPU and heat sink if the computer continues to turn off unexpectedly. Heat sink compound is a pasty substance that fills the space between the heat sink and processor, which increases the heat sink's ability to absorb heat from the CPU. But worn heat sink compound won't properly redirect heat away from the CPU. Power down your computer, disconnect its power cables and open the case. Unplug the CPU fan's power cable from the motherboard, remove the heat sink and fan combination from the CPU, and then apply the heat sink compound to the CPU--refer to your product manuals for details on reapplying heat sink compound.
Thanks .
Have a great day.
Oct 03, 2010 | Dell Inspiron 537s PC Desktop
My E4252 shuts down on boot-up> I have tried changing the psu to no avail. If the motherboard is cooked where can i get another?
It is not the motherboard that is cooked it is the processor overheating to correct this problem you need to do the following
Remove the Heatsink from the CPU and re apply heatsink compound to both the CPU and the heatsink then replace the heatsink onto the CPU. the reason for the overheating and shutdown is that the connection between the heatsink and the CPU has become "Aged" and no longer transfers the heat like it should
Jul 09, 2010 | E-Machines eMachines Refurbished EMA...
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
System over heating
Simple reason is Replace your SMPS .
Apr 02, 2009 | ASUS K8N-DL Motherboard
Random shut down
Yes.... over heating can and will cause a system shutdown..
Download and install speedfan ( http://www.almico.com/sfdownload.php ) It will most likely tell you how hot things are really getting......
Depending on what cpu you have, you may have a thermal paste problem, you may need to remove the heatsink and re-apply heatsink thermal paste to the bottom of the heatsink and reseat ontop of the cpu. This will void any warranty if you PC still has any left.
Jan 07, 2009 | EliteGroup GeForce 6100SM-M Motherboard
About motherboard
I believe you have overheating problem
Remove side of case and clean all fans including power supply one then clean and remove all fluff and dirt from Heat sink vanes.
Then vacuum out case include all vent holes and behind power supply ones
Then restart computer
Oct 10, 2008 | Intel D865PERL Motherboard
Intel D865PERL Motherboard Logo
200 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
