Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
2007 craftsman 20HP flooding
I think I have a flooding problem, but would like some guidance on resolving... I can run the mower for any period of time, b ut when I turn it off, I can't get it to run after that. It will take an hour or so before it will turn over again.
  • johnc9999 May 11, 2010
    When you say "before it will turn over again", do you mean you turn the key but the starter fails to crank the motor, or does the motor crank but fail to fire and run?
  • 123 Answers
Do you get a strong smell of gas. Check your oil and smell it to see if gas has gotten into the crankcase. It all is well there it sounds like you need to gap the valves.
Posted on Oct 03, 2009
Why is my 20hp B n G Keep flooding?
check that the float valve is closing fully may have dirt under seat.
Aug 27, 2012 | Briggs & Stratton Starter Scott's Equip...
My 2001 craftsman, 20hp lawn mower will not start for flooding the cylinders, what could cause it from putting too much fuel in there
with the newer fuel that we have the needle valves in the carb don't seat anymore replace the needle and seat change the oil if possible add a shut off valve inline to the carb and close it when not in use
Jun 24, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Kohler 20hp Craftsman mower started leaking fuel out of air filter and exhaust
i have been finding that the needle valve in the carb has not been seating from the newer fuel replace both the needle valve and the seat change the oil and you should be good to go i add a shut off valve to the ones i service and advise that the fuel be shut off when not in use and run the carb out of gas when not using for ever day
Jun 18, 2012 | Garden
I have a craftsman rider lawn mower,917.2720601 and my manual is not spesific enough to show me how to assemble the mower deck to the mower.i also am missing some parts and do not see them on the parts...
http://www.hammerwall.com/Manuals/Craftsman/Description/917.2720601/Craftsman%20Lawn%20Tractor%2016.0%20HP%2042%20in.%20Mower%20Electric%20Start%20Automatic/L0203168/
There is a manual with the part numbers and names and step by step pictures not sure if its the same manual that you have hope it helps
May 11, 2012 | Craftsman Garden
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 19.5 - keeps flooding getting too much gas
I think that you have a sticking float in the carb. You probably will have to rebuild it. hope this helps
Sep 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
When my 20hp Craftsman lawn tractor cranks it does not quit pumping gas in to the carburator, and floods it out - what do I need to look for??????
Sounds like you have a Float in the Carb has a hole in it or it is getting stuck open there is a needle valve that it pushes on when the bowl is full and it sounds like its not or something is stopping it,, did it have gas in it all winter? ,, I would buy a Carb kit for that model and change out all the parts that come in the kit and clean the carb
Apr 17, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
187 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
