Question about Belkin Wireless-N Wireless Router with 4-Port Switch
Wired connection frequently disconnected
After setting up the wireless connection the wired pc's disconnect internet connection within 15min, only power restart router helps, please give me a solution ???
    Problem Solver:
  • 13 Answers
You might check the admin setup to see how long the DHCP lease time is. Or you can go to a command prompt and type "ipconfig /all" no quotes, it should tell you at the bottom.
Posted on May 24, 2009
Keeps disconnecting
What disconnects?
1) wireless adapter
1b) internet connection
2) wired connection
2b) internet connection
3) power adapter
4) monitor
5) other connects
Nov 07, 2013 | Computers & Internet
Unable to connect to my wireless internet connection on laptop
you could try updating your wireless network driver. click start and right click computer, click manage and then device manager in the computer management window. look for network adapters in the main window and click to open drop menu. find the wifi adapter, right click and click update driver software. you will need to do this via a wired connection
Mar 08, 2012 | Samsung P30 Notebook
Cannot get eee pc 1001pxb to connect to the internet. it has connected to a wireless internet, but not the wired connection. I have linksys wireless g router, but it is hard wired to all my computers. i...
Good Morning.
Do not worry, We will fix the issue for you.
Please open control panel >> network and sharing center >> if you see wireless network connection >> please disconnect it and >> connect the lan cable or wired cable to the laptop and start browsing.
This will fix the issue.
Jul 06, 2011 | ASUS Eee PC Netbook
How do you remove or uninstall Firefox when a hacker is using the browser to get to your computer? Please he won't let me uninstall it from the add/remove programs list, it's making my comp go slowly
Disconnect your Internet connection first. If you're using wireless, turn off your wireless connection. If you're using wired, disconnect the wire first. If your computer is not connected to the Internet, no hacker can access it.
Nov 24, 2009 | Compaq Presario 5000 PC Desktop
Problem with router; Msn gets disconnected frequently.
It could be the proxy or firwall setting in the router.
you need to open the router page and check the firewall and proxy setting ..
or you can download the tool from the below site
www.ultrareach.com/
and it will take off all proxy setting and you winows messenger should work.
This should help you identifing if its a proxy issu.
THanks & all the best
May 27, 2009 | Belkin (F5D8231-4) Wireless Router...
CANNOT CIONNECT TO WIRELESS ORANGE NETWORK
Is this a new laptop, or was it working and just stoped.. When it says internet connection is disconnected, did you try setting up the wireless settings, or just turn it on and it didn't work. If its the latter, right click on the network settings "properties" and see if it's showing. If not then look on tht same page and select "create a new connection". It will set up our laptop, just follow the directions
You may be asked to connect a wired connection to yyour router, until it gets the information it needs, at some point it will ask you to remove the wire, that should get u going, ty
Jan 22, 2009 | Acer Aspire 4315 Notebook
My wired pc keeps discconecting from internet
Check for wire loose connection and then any time setting for your dhcp connection. If they are ok check your network connectivity do as follows.
Startup
run
type cmd
at the prompt type ping <your router ip address> -t
kepp watching the reply
use your computer as normally and check when it gets disconnect by watching above
may be some corrupted program send packets in an un usual rate (it can be virus/trojan) so the router blocks those port and your computer disconnect from the network.
Rather from all the above change the PCI Network adapter replace with a new network card.
Hothawk
Jul 15, 2008 | MSI Wireless-G RG54G3 Router
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
My wireless is not working...
You will have to remove the cable from your wired card first, as your pc cannot open 2 networking ports and obtain an ip address. The wireless card needs to be able to pick up the address and dns address from the router, so when your disconnected from wired card, your wireless should search for wireless connections and allow a conection.
Feb 23, 2007 | IBM ThinkPad T21 Notebook
Open Questions:
Belkin Wireless-N Wireless Router with 4-Port Switch Logo
208 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
