Question about Jenn-Air JGR8850 Gas Kitchen Range
Gas smell continues when gas burner is lit
I have a Jenn-Air downdraft gas range. When the burner is lit I smell excess, unburned natural gas. This is not just at or just after start-up; it continues for the entire time the burner is lit. More details: I have replaced the grill burner unit with a second two-burner module. My problem is that when either the new or the original two-burner unit is inserted into the left side of the stove (the side that originally housed the grill unit) we get the excess gas smell. Is there too much gas coming to the left side? Is there some gas flow adjustment that I can make?
  • 552 Answers
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Posted on Mar 17, 2008
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
  • 3182 Answers
SOURCE: Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Posted on Jan 20, 2010
  • 254 Answers
SOURCE: My Jenn Air model number is worn off and I need it
if u need just an electric burner 6" or 8" u could buy a whirlpool element it would work just fine take the part to a local parts place or if none available u could order like a mp15ya or a mp21ya or something similiar,, go to and type those two part numbers in to see a picture .. then shopa round hope this helps
Posted on Jan 28, 2010
Gas smell from one burner
get guys back, leak test it. you can use a soapy solution like dishliquid mixed med think and brush it on connections and look for samll bubbles, make sure you have gas on to do this!!
Feb 03, 2010 | Jenn-Air Pro-Style JGCP636ADP Gas Cooktop
Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
Jan 24, 2010 | Jenn-Air PRG3610 (NP) Gas Kitchen Range
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Gas burners lit, but electronic ignition still clicks
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
Mar 13, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's?
Mar 09, 2008 | Kitchen Ranges
Gas Burners Not Lit Completely
sounds like there isnt the right amount of gas coming out of the orifice. orifice could be partially plugged
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JGR8850 Gas Kitchen Range Logo
403 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
