Question about Motorola Mobility PEBL U6 Cellular Phone
Screen not visible
For no reason the screen has disappeared. I can vaguely see the box where
a message in but can't get menu, or see what is happening on the screen.
Phone still calls if i know the number i need to ring. Please help
  • 490 Answers
U need to see the hardware vendor for this problem because the diaplay settings have been damaged.So take ur handset to the service cenntre and ur problem will be solved.
Posted on Oct 20, 2007
Led problems
Why do I have a green line on the edge of my screen? If you have a thin green line on the edge of the screen when using an HDMI cable to connect to a cable or satellite box this is usually caused by the box.
To test to see if this is a box issue you will want to take the following steps:
If the TV has a Horizontal position setting in the menu you can adjust the position to see if the line disappears.
You can also change the Wide setting to the Zoom or Panoramic option to see if the line disappears.
If the line disappears you will want to look into getting a different source box.
Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them.
2. Check your Advanced Video settings in the Vizio TV menu some of our Vizio televisions will allow you to adjust the following settings under the Advanced Video settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP section. It will say either "reset all settings" or "system reset". We recommend that you reset all settings as well to see if this resolves the issue. If this does not resolve your problem please contact our technical for further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
Dec 04, 2011 | Televison & Video
After a power flicker our TV Has a large black square in the middle of the screen. Problem is that the commercials are AOK but as soon as regular programming resumes....black box. HELP!!!PLEASE!!!
You have the closed-captioning turned on and set to "text" mode. It probably got set this way because of the flicker. Use the remote (or front panel menu buttons if this set has them) to get into the closed-caption settings. Turn captioning off and the box will be gone.
In case you're curious, the reason this happens is that the set clears the screen where the text will be displayed, but there's no text. On programs or channels without captioning the box disappears.
Jan 27, 2010 | Televison & Video
Cannot find c:\msoffice\excel\LIBRARY\AUTOSAVE.XLA
Something happened to your autosave add-in.
You don't specify Office version, so I must be vague: you have to find an "Add-ins" option in the Excel menu, and disable the Autosave Add-in.
If you want the autosave function, you'll have to reinstall Office.
Nov 28, 2009 | Microsoft Windows XP Home Edition
Moved Icon
from the main menu press this
menu button
menu button use scroll to select unhide all
find you icon, unhide it , then press menu button again and select hide all
Feb 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
Music disappears automatically!
there a new virson 7.6 untic the boxes when you plug your mp3 and just tick the box you need
Jan 27, 2008 | Apple iPod MA446LL/A MP3 Player
Motorola Mobility PEBL U6 Cellular Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
