Question about LG LRBN20510WW Bottom Freezer Refrigerator
2006 TOP/BOTTOM MAYTAG COMPRESSOR MAKES LOUD D RILLING LIKE NOISE
LOUDER IN FFREEZER
  • 999 Answers
Yes it is. All the cooling is done in the freezer and air is circulated through the frig.
Eric
Posted on Jun 24, 2009
My compressor wont come on
Check for a bad start capacitor/relay. Also check all wiring and contacts for integrity. Get it to run. If loud noise on start up or shut down that is caused by a broken internal spring (usually three) that hold and center the motor inside the container. If one breaks the startup torque will twist the motor up against the shell making the noise. Has no effect on operation and/or longevity - just noise that can be lived with. If you shim compressor in the opposite location of spring break you may eliminate start up noise completely.
Aug 28, 2017 | Samsung RS263TDBP Side by Side...
My fridge is making a god awful noise... it's still cooling, but the noise is off and on and each time it comes back it's louder and louder.... any suggestions??
When do you hear the noise? What is the refrigerator doing when the noise comes back?
If it is when the compressor kicks on, I would check the mounting brackets for the compressor and make sure they are tight.
If it is a clatter then I would check the colling fans (top and bottom and make sure the blades are striking something.
Where you say it is getting louder and louder, I would check for ice buildup on the evaporator fan in the freezer section.
Jun 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sharp winning or piercing compresser noise. is it normal? maytag refrigerator model # ptb1954grw.
maytag frig is noiser than other brands . amana also and jenair and majic . all made by maytag. this units have a compressor noise louder than most . there comp are larger and some what louder . but i would say you have a normal maytag .. mm i was maytag largest dealer in utah for many years and your statement is very common .. some times the copper lines or fans cause louder noises . so if to loud you should have ti ck'ed . mm
Aug 10, 2010 | Maytag Refrigerators
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Maytag washing mchine makes a loud noise when on spin.
It sounds like your main bearing has gone out. It's quite an expense to fix and generally isn't worth fixing even if you do the repair yourself as the parts run about $600 by themselves and it takes about 1/2 a day to replace them. You can't replace the bearing itself so you have to replace the rear half of the outter tub and the inner tub.
Mar 29, 2010 | Maytag Washing Machines
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
When spinning it seems the washer is getting louder and louder during the spin cycle. It is a very steady noise no grinding to it. Maybe a bearing?
make sure heavy items are evenly distributed in the barrel. if to loud , stop the machin by openning the lid and make sure the weight is evenly distributed. never just throw laundry in , place it so wieght is evenly placed around.
Jun 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
LG LRBN20510WW Bottom Freezer Refrigerator Logo
116 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
