Question about Garden
My pond pumps faulty
Everytime i turn on my cascade 1500 pump it trips the electric, does anyone know why? please help
  • 634 Answers
Sounds like the pump has shorted out internally and needs to be replaced, try on different circute first to see if breaker is not faulty
Posted on Jul 17, 2009
Sta-Rite 1HP inground pool pump Every time the pump turns on it trips the breaker, after taking the motor appart and lubing it up I could get it going but once off for a period of time on startup it will...
Any time an electrical appliance trips a breaker there is only several causes:
1 - appliance is pulling more amperage than the breaker was built for.
2 - breaker is faulty
3 - a "hot" wire is touching "ground"
4 - screws (where wire is attached) in the pump or breaker are loose
1 - If the appliance is pulling more amperage than the breaker (or wiring) will allow, then check the appliance to see what amperage it's rated at. If this is more than the breaker will allow, you'll have to plug the appliance into a circuit that will take that amperage. If the appliance rating is within the limits of the wiring & breaker, then check #2, #3 or #4 above. If everything is okay with the remaining possibilities, then you have problems within the pump. Do it yourself'ers usually have a bad time when they open an electric motor. I suggest you take the motor to a electric motor repair shop or seek help from the Sta-Rite pump Customer Service.
Jul 01, 2010 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
Jacuzzi magnum 1500
Pool pumps are on a circuit breaker. There should be one nearby. Check the breaker first. If the switch is halfway on, it has been tripped. Turn the breaker all the way off firmly and then back on to reset.
Also there is a thermal breaker in the pump. Turn the breaker off and wait a few minutes. It should reset as well.
Also, if you get alot of debris in the leaf basket of your pump (mine is very tempermental because it's next to a small needled deadora tree...) Pull the leaf basket, with the pump and breaker off, reach into the inlet of the pump...it's below the basket and off to one side. Make sure it's clear of debris.
Then take the cap off the the electric motor end of your pump shaft. If it's jammed, take a crescent wrench and turn it back and forth until it frees up. Then double check the inlet again with your fingers.
If the pump still has electrical and it's not able to turn, you'll need to take the motor off the pump ...there are 6 bolts that you need to remove and then the motor with the impeller will come loose from the pump housing. There a 2 small allen screws to remove to take the impeller housing off. you can then clean all the debris out of the pump if needed.
IF there is not electrical to your pump motor, it may be that the motor has burned out, but check all the above first if there's still a hum in your motor when you turn it on....
Good luck on this and let us know if you need further help!
K
Jul 30, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Jul 25, 2009 | Cascade 1400 Gph Pump
Pond pump trips safety switch
Check first if there's continuity between the electrical lines and body of the motor. if there is, then you have a line to ground fault in your motor. If there's none, check the resistance between the phase windings. If you get an infinity value, then the motor windings is shorted. If you get an acceptable resistance value, try to rotate the pump with your hand. If there's a considerable resistance, you might have a defective motor or pump bearings.
Jun 09, 2009 | Plumbing
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
Pw5500 Calpump not working
replace the breaker with a higher amp breaker . Thank you for useing fixya please take the time to rate me
Feb 09, 2009 | PW Calpump Pw5500 Waterfall Pump 5750 Gph...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
How to repair my Cascade 1500 fish pump it just stoped working
First check age as they have a three year warranty. If not, the impeller needs to be checked for blockage or breakage.
Nov 22, 2008 | Garden
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Garden Logo
211 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
