Question about Canon PowerShot A75 Digital Camera
Camera turns on, but no picture, using new batteries
Flash works OK, system set in auto. Menu works func. button works and disp. works but, no picture
  • Canon Master
  • 4,738 Answers
First try pressing your DISPLAY button to see if that corrects the problem. If not, then the problem is likely a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 24, 2009
How to print pics with the date stamp from canon A580
The date stamp feature on this camera will only work in postcard mode- resolution set to 2M (1600 x 1200) and compression set to fine. You have to set the picture mode to that first. You also have to set the date and time if it isn't set already.
To set the mode quickly, set the mode switch to camera, turn the mode dial to A (auto), then press Func. button, scroll down to the "L", scroll across to the mountains with the clock dial, then press the Disp. button to turn date prinitng on and off.
Nov 28, 2010 | Canon PowerShot A580 Digital Camera
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
Apr 03, 2010 | Polaroid A500 Digital Camera
Canon IXUS 80IS - I can't turn the flash on
When this camera is in "Auto" mode the only flash functions available are Auto or Flash Off - in order to get the option of "Flash On" for all pictures you have to put the camera in "Manual" mode - to do this:
-Set the mode switch to the camera icon
-Press the "Func./Set" button
-Use the left or right arrow keys to set it to Manual mode (its icon looks like half a camera with the letter M beside it)
-Press the "Func./Set" button again to save your mode change.
Now when you press the flash button and cycle through the choices there will also be a "Flash On" option.
Jul 26, 2009 | Canon IXUS 80 IS Digital Camera
I can't view my pictures after the shot,it very blerr
I'm not sure if you are talking about the quick view of a picture just taken, or using playback mode to view shots taken. Either way, I suggest changing batteries so they are fresh.
There are 3 different LCD choices when in "Shooting Mode."
Press "DISP."
The display mode will change each time you press this button.
1- Standard (no info displayed, just pic)
2- Detailed (infor displayed)
3- Off
If you have tried this, then you may want to perform a reset to the cam. This will reset any screen/LCD settings that may have been changed.
Goto the Setup Menu and select "Reset All." Select "OK" and press "Func. Set."
This reset WILL NOT reset the following:
-Current Shooting Mode
-Date/Time, Language, & Video System settings
-White Balance Data (of you have custom settings changed in the custom white calance function)
Apr 30, 2009 | Canon PowerShot A450 Digital Camera
Canon A620, I can review pictures taken, func set and menu, but I can't see what the lense sees.
Are you able to take pictures with the shutter button, and do the pictures come out OK? If so then it's likely that you accidentally pressed the DISP button on the back of your camera. Press it once more to turn your display back on.
But if the pictures are also coming out black like the display, then the problem is more serious, and is likely a stuck shutter (this cannot be repaired by the average person). This would require professional repair. Call 1-800-OK-CANON to arrange repair.
Mar 21, 2009 | Canon Cameras
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Black screen when camera is on...did you get an answer?
One configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Jun 21, 2008 | Fuji FinePix F700 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Shutter button problem
This may be the same problem that requires you to press the LOCK button to actually take a picture. I found a solution and have posted to the questions mentioning the LOCK problem. Anyways, here goes, if that is not the problem please disregard what follows:
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 15, 2007 | Nikon Coolpix 8700 Digital Camera
Canon PowerShot A75 Digital Camera Logo
241 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
