Question about Microtek SCANMAKER 5900 Flatbed Scanner
Can't use scanner for copying.
When I try to use my 5900 to copy stuff, the copy button doesn't work. I've tried going to the configuration set-up but all the copy button info is greyed-out. Help!
Where i find umax astra 4100 driver for free
Posted on May 25, 2009
Scanmaker 5900
try create new folder rename new folder in temp as (Temporary) copy drivers for XP 32 bit in directory Temp click with right button on mouse on program then with left mouse button click properties and with left button click Compatibility and mark Run this program in compatibilitiy mode for Windows xp (Service Pack2) then click apply and ok after that run driver and install
Jul 18, 2014 | Microtek SCANMAKER 5900 Flatbed Scanner
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
All-in-one printer/scanner not working
did you installed software from the cd that came with it?
windows installe it as a scanner that you can use from Control Panel->scanner and cameras following the wizard...
to use the buttons on the scanner you must install software and configure it
Mar 15, 2009 | Lexmark All-in-One Printer, Scanner &...
The buttons on the Scanner itself will no longer work.
You should be able to reconfigure the button settings by clicking on the "Settings" button in the CanoScan Toolbox application. Although the default setting is Scan, Copy and eMail, each of the buttons can be configured to do whatever operation you choose.
Oct 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Won't copy
try this...
start, programs, canon scangear toolbox,
A little box like this should appear
press on the cog icon
Select the copy tab and ensure that the "link to" is set to DRIVER, and press the SET button and select the printer you want to copy to from the dropdown, then OK, OK
post back results and if required I will give more ideas to try
Jul 05, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Diference between Cold boot and warm boot
A warm boot restarts the mobile computer by closing all running programs. All data that is not saved is lost.
A cold boot also restarts the mobile computer, but erases all stored records and entries from RAM. In addition it returns formats,
preferences, and other settings to the factory default settings.
Apr 07, 2008 | Symbol MC1000 Barcode Scanner
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Microtek SCANMAKER 5900 Flatbed Scanner Logo
136 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
