Question about Garden
Won't start Won't even try to start. Checked plug. Doesn't seem to be fouled. Has been stored for several months. Put in fresh gas/oil. It's a Poulan 2155.
  • Anonymous May 25, 2009
    As far as I know, the plug is OK. It was working fine in November but has not been used since then. I took the plug out and cleaned it but it seems to make no difference. The primer pulls fuel through the visible part of the fuel line. Using same fuel as before. Would I check for fire by taking the plug out and still having it connected while pulling the rope through?
  • Jim Parker
    Jim Parker May 11, 2010
    Need more information. Does it have fire.
    Jim
  • 1,040 Answers
Yes, take it out and prop it against the head of the motor. you may have to get somewhere dark so that you can see the spark. But you may not want to hold it with your fingers as you pull the rope, it may bite! If you have no spark, then you have a bad plug or a bad ignition module.
Jim
Posted on May 26, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Did you figure out the problem?
    Jim
Put new gas and new oil in and tried to start. Would stall in few seconds when could start. There is fluid dripping from the filter area
Hi Anonymouse:
I'd be checking to make sure that the correct fluid in the correct amount was added to the correct place.
Start with the oil. Check the dipstick or indicator level. Too much oil will stop the engine. Sometimes gas get accidently put in the oil filler if an inexperienced person is helping with the maintenance.
Gas.......... Make sure that oil was not accidently added to the gas tank. Drain the carb and put fresh gas in the gas tank.
Spark plug.;.... pull and check for fouling. Replace if not really clean. Check for hot blue spark before re-installing.
This should get you back digging up the garden very soon.
May 15, 2015 | Garden
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
POULAN RUNS GREAT THEN DIES WILL START UP AGAIN THEN ABOUT THE TIME YOU START TO CUT WILL DIE AGAIN AND KEEPS THAT UP
I hope you are using fresh gas, as when gas gets old from previous season use, it can be the problem. I have seen a spark plug fouling, giving the same results though. I don't know the hours you have run the saw, or the severe use it may have seen. Have you checked air cleaner? fuel supply? If it was set up for a long period of time with old gas, carb may need cleaning.
Hope all these questions stimulate some possible problem resolution
Jan 12, 2013 | Poulan Garden
17 hp briggs smoking badly . found oil in gas. took head off cleaned valves and piston. took off carb and checked float. checked breather seems ok. starts right up. littlesmoke then more as it warms up...
The only way oil can get into gas is if someone adds oil to the gas! Drain gas tank. Put Clean gas in and try it then. Oil in gas usually fouls the plug so if it doesn't run by now, check the firing in the plug.
Dec 16, 2011 | Measuring Tools & Sensors
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
13 horse Honda presure washer (landa) won't start. Been sitting for several years. Checked plug which looks new.. Maybe wrong one? Will sypone old gas and replace. What about plug, fuel filter and air...
you can try and remove the old gas the carburetor and perhaps the fuel filter are most likly fouled with gunk from the old gas. When gas sits, over time it forms a thick gummy deposit that can clog carburetors, and anything else. try fresh gas with some carburetor cleaner (NOT the kind in the spray can) mixed in. It may need to have the carburetor rebuilt or replaced.
Jul 10, 2011 | Honda Garden
My mantis wqn't start. I have cleaned the fiter changed, the spark plug and put new gas in it.
If it has been sitting for a few months, remove and check your spark plug. If it is wet it is getting fuel. Replace it if worn or fouled but that is doubtful unless you have had it for quite some time. Then get some 100% acetone (Wal-Mart or a beauty supply store) and add a couple of ounces of it to your fresh gas mixture in the mantis fuel tank. This will clean out build up in your carb, etc. Try to start it several times. If unsuccessful after several pulls, let it set for a while. Do this several times until it sounds like it wants to start. Using this procedure it eventually will. This website has a video for detailed instructions to adjust the carb should that be necessary. It is actually quite simple. http://www.alamia.us/mantis_parts_s/148.htm
Feb 12, 2011 | Mantis 2-Cycle Tiller
I have a Poulan 450 push lawnmower, and it's only a month old, and I've only used it once before to cut my yard. It worked perfectly, and now three weeks later I added gas to the mower, and the oil level...
Remove spark plug,it may be fouled and have gas on it,clean it and then reinstall and try if that doesn't work,try a new one.Also check the air filter,may need cleaned or replaced.
Jul 09, 2017 | Poulan "" Push Mower
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Tryed to start stored engine oil came up in carb.
Hi, I would start by putting in a new spark plug. drain gas, and put in fresh hi octane gas.
If this doesn’t work for you please write back, Thanks,
Nov 22, 2008 | Garden
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
