Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yardman push mower starts but doesnt get full power
Mower starts and runs fine but doesnt get full pwer blade spins eveything seems to be worrking right but it just doesnt seem to get engough power to cut gas. i clean the carbs changed the plugs not sure what else it could be. i was thinking maybe there is a seal that is worn but not excatly sure which one it would be if some one could tell me that would be great instead of taking it apart and playing guess and check. thanks for all your help.
Check for some water in the gas.
Posted on May 26, 2009
Hi I have a Hayter L324 mower there does not seem to be much power to all three cutters, thick grass will stop the blades from turning. This was not a problem last time I used the machine.
Hi Alan, it might be the nut or bolt is underneath its a disk or one big bar the thing that holds the blades to the motor, if you can spin that without the motor going that has to be tight. Cheers Greg.
Jun 11, 2016 | Garden
Will not start. Is there a safety switch to check on?
switches on the seat, blade engagement lever and clutch/brake pedal
Sep 22, 2014 | Yardman Yard Man Select Series 42"...
Yardman troubleshooting
More than likely the bearings on the mower deck that your lawnmower blades bolt to are seized or are close to it .Disconnect the negative battery cable from battery before you get anywhere near the underside where the blades do there business. Better yet, remove battery completely, and have it tested at AUTOZONE for free. While battery is out , check free spin of deck blades. Any resistance or grinding while blades are disengaged >debris , fence wire , rope tarp, etc.. or bearing failure. [DUE TO THE NATURE OF THIS PROBLEM AND THE POSSIBILITY OF SERIOUS INJURY, I WOULD STRONGLY RECOMMEND TAKING IT TO BE CHECKED AT INDY SHOP. ... ALTHOUGH COMMON SENSE WILL GO FAR IF YER MECHANICALLY INCLINED. .. YOU TUBES VIDS ARE A GOOD STARTING POINT. NOTE:BEARINGS CAN BE REPLACED,, WHEREAS A HAND OR A FOOT ...AINT AS EASY. Good luck
Mar 21, 2014 | Garden
Mtd yardman wont start getting feul no spark detected
they go bad rarley make sure your blade brake switch is not ingage killing spark
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Blades will not turn on lawn mower
You haven't given enough information of the problem. The blades themselves wont turn when you try to spin them by hand or they wont turn when you engage them with the lever or the switch?
Jan 11, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Does not seem to have power when pushing snow wheels just keep spinning even with wheel weight and chains
Sounds like power isn't the problem if the wheels keep spinning. Traction is the problem. You say pushing snow, that leads me to think you have a plow on it not a blower. I think this machine is too light for plowing, unless its light fluffy stuff. It would do better with a snow blower. Hope this helps.
Dec 10, 2010 | Yard Man Yardman Riding Lawn Mower 38in...
My 22" MTD Yardman push mower runs too slow to cut much grass. How can I adjust it to run faster? It has no speed selection that I know of, only the handle bar that must be held tight to keep it running....
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
328 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
