Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Error code LO
Just installed, new hayward pool heater H200FD. Keep getting error code LO. What should I check.
    Problem Solver:
  • 5 Answers
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
Posted on Jun 07, 2009
  • Hayward Master
  • 1,631 Answers
LO is simply informing you that the Heater is not sensing proper water flow through it! A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Posted on May 25, 2015
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
My hayward pool heater gives me a code sb what part is this
Possibly failed keypad, or stuck key on keypad.
This product should be under full warranty, and installer should be called.
Hayward 350 product manual: Error codes start page 38 do not show Sb
http://www.hayward-pool.com/pdf/manuals/Manual285.pdf
However Sb error code shows on following manual as 'Keypad failure' or 'stuck key'... one of the keys is stuck longer than 30 seconds, but control will still function, replace keypad.
http://waterheatertimer.org/pdf/Hayward-error-codes.pdf
Sep 20, 2012 | Hayward H350FDP Low NOx Propane Gas Pool...
Our hayward heater H250 model was installed last year.. this year it started up after the winter no problem. We put it on Standby mode while the poolliner was being replaced and not it will not come on.....
Thank you for posting your question here on Fixya.com.
A 'LO' error code for a Hayward heater is a limit string open error. If the limit string opens the heater shuts down and goes into lockout. Automatic restart is 2 minutes after the error condition is corrected and the limit string closes.
The limit string is a series of switches designed to turn off the heater if air or water temperatures exceed a safe operating limit.
The problem may be faulty a switch(es) but is far more likely to be a system condition the switches are reacting too that needs to be corrected. Low flow of combustion air due to obstructions around the heater or the vent; low flow of water through the heater allowing too high a water temp; Poor venting or sooted-over heat exchanger causing flame rollout; inlet and outlet hose connections reversed; these are all conditions that should be eliminated if they exist.
If you are not familiar with these switches or the conditions described you may want to consider calling in a professional. Hayward can refer you to someone in your area who is. Call Hayward at 908-351-5400 or try the website locator found here. It is likely to still be covered under warranty.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 08, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Getting LO error
Lo is an error code dealing with the safety loop, hi limit switches, water pressure switches. Check for continuity and the wiring between the hi limit switches and the water pressure switch. Also, check to make sure the filter is clean and the pump basket is empty. These also can cause a low flow situation that will cause the pressure switch to not close properly.
May 23, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
My hayward heater gives a LO error when trying to heat. you cant put the heater either in pool or spa mode, then set the temp. The temp flashes then you get a LO error. I've checked the valve settings to...
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
Feb 15, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Jun 20, 2009 | Hayward H Series Pool & Spa Heater 400k...
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
May 27, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H250 giving me a "LO" error code and does not turn on.
9 times out of ten this means that you have a faulty water pressure switch. It could also be a limit switch, or air pressure switch. Make sure the filter is cleaned, and all valves are in the correct position. Once you are CERTAIN that water is flowing through the heater, you will need to short each individual component to find the faulty one.
Apr 10, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H400 heater problem
LO usually indicates low water pressure. Check the pressure in your filter. You may need to backwash. If the filter is to clogged then the water pressure in the heater is so low that it won't activate the pressure switch. While checking the pressure turn the pump off and then on to make sure the pressure gauge is actually working. Also check the pressure coming out of the inlets into the pool. You should be able to tell if you have sufficient water pressure.
Jan 24, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
1,616 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
