Question about i-mate JAM Pocket PC
Backup battery is not charging not visible.backup battery none
My imate jam has been working fine until I replace the cover. It now say backup battery very low, to prevent possible date loss,replace or rechage your battery according to the owner manual. And sure that the backup battery is good cause it has been work fine with and I event have two of it that give me the same massage.
    Guru:
  • 832 Answers
Hi thanks for using fixya!
I recommed that you bring your Imate PDA to a service technician to check further the error. It is not a good sign, especially if there is a problem with the back up battery.
Regards!
Posted on May 25, 2009
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
How do I prevent loosing data when my battery discharges
Hi. Actually, on pocket pcs there's a backup battery onboard, but in your case maybe backup battery is dead. So you can have that changed or you can charge your PDA on regular basis. Hope this helps.
Jun 28, 2009 | Toshiba e355 Pocket PC
The phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
Good luck
May 23, 2009 | i-mate JAM Pocket PC
Imate jamin not turning on and not charging
I had the same problem with my Jamin so sent if off to the technician who informed me the Jarmin's internal circuitry prevents the phone being charged when the battery is under a certain voltage so when you use a plug in charger because the battery has very low power it does not trip a circuit in the Jamin to start the charging process. The only solution to to take the battery out of the unit and charge it with a stand-a-lone charger. Hope this makes sense.
Sep 13, 2008 | i-mate JAM Pocket PC
Imate jam back up battery is not cahrging...
i have imate jam if it is turn off when i turn it on then my all programs are delete and back up takes so much time. is there is an other solution
Jul 10, 2008 | Computers & Internet
Total loss of software
try with sone other card once.
Jan 21, 2008 | i-mate JAM Pocket PC
Imate jam problems with power n network coverage
Hi try a hard reset.. i think a firmware update will remove the problems !!
Jan 04, 2008 | i-mate JAM Pocket PC
IMate JAM battery drained off
When I bought my Imate I had the same problem. Put the charger on it and leave it for an hour or so and check the results. Just so the backup battery gains charge.
Sep 07, 2007 | i-mate JAM Pocket PC
Camera won't stay on; date/time won't stay set
Are you sure the lens is actually going all the way out? If there is debris in the zoom gearing it can cause the lens to stop extending which would in turn cause the camera to re-retract the lens and show an error. Other possible explanations are that the sensor which determines when the lens has reached full extension has failed, so the camera keeps extending the lens until it reaches the physical limit - and then behaves just as if there was a jam as described above. The fact that this occurs both when you power on and power off the camera leads me to think this may be the case. The loss of date and time settings is due to a dead backup battery. Check your manual to see if this is replaceable by you or if it requires disassembly. David Millier Advance Camera Repair
Feb 17, 2007 | Nikon Coolpix 4300 Digital Camera
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
i-mate JAM Pocket PC Logo
311 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
