Question about Danby DPAC8020 Air Conditioner
UNIT SHUTS DOWN AS SOON AS COMPRESSOR KICKS IN
I have an Everstar MPA_08CR portable AC unit (2 years old) the fan blows and everything works fine but as soon as the AC comp kicks in the unit will shut down and the green (DRY) light will flash forever, and I cant turn the unit back on without unplugging it and plugging it right back in. The water tank is seated proper, intake is perfectly clean and there is not any restriction on the exhaust. I have tried it on several different outlets and there is not any power surge. Unit worked perfect befor I put away for the winter. Suggestions??
  • fdisc May 27, 2009
    Does this mean the compressor is out? I just didnt understand the term. Thank you,
    Fred
  • 52 Answers
Hi fdisc I feel quite sure your compressor is going straight to ground you need to get someone to check the comp, for its resistance and he or she will soon let you know for sure.
Regards
Steve.
Posted on May 25, 2009
  • Stephen Palm May 27, 2009
    fdisc, sorry for the confusion but yes I feel that it may be the case yes.
    get someone to check it and the system like I said ok.
    Steve.
2 Suggested Answers
  • 400 Answers
SOURCE: Everstar MPA 08CR Portable AC unit. Water full
Your float switch is faulty, replace.
Posted on Jul 02, 2009
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
Everstar mpm 08cr bb4 manual
Try Googling (Everstar)(mpm 08cr bb4)(manual) without parens.
Oct 23, 2017 | Everstar Portable Air Conditioner Everstar
My everstar portable ac is not running properly. In cool mode only the fan is running if I shut off the unit and restart the compressor comes on and then shuts right off the green light blinks briefly and...
Ed, there are several things that can cause this problem, but all are solvable.
1. The current temperature setting is not low enough.
2. The air intake filter needs to be removed and cleaned.
3. The water collection tank is full and needs to be drained.
4. Obstruction in the exhaust hose(s).
Be sure to turn the unit OFF & unplug it, before attempting any service work on the unit.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whynter Portable Air Conditioner
I have an Everstar portable air conditioner Model MPA-08CR but when it is working for 10 minutes...it is working fine cooling the desired space but the next 10 minutes it is only working like a fan...then...
The problem may be that you don't have the temperature set low enough and the unit reaches the set temperature quickly and then only the fan runs. Try lowering the set temperature.
Aug 05, 2011 | Heating & Cooling
How do i use the heater function on the everstar portable air conditioner model number mpa-08cr?
Is it an automatic?If yes observe the operation of the system because It It will automatically operated.
Nov 30, 2010 | Heating & Cooling
Have a portable everstar ac model MPM2-10CR-BB6 blow strong but no cold air.
check temperature setting and the mode on cool if ok check the compressor is working with condenser fan if are working the unit has a loss of refrigerant . if the compressor is not working and voltage is correct may be the capacitor need replacement
Sep 03, 2009 | Heating & Cooling
Jul 02, 2009 | Heating & Cooling
Danby DPAC8020 Air Conditioner Logo
618 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
