No cool air coming into house.
"The unit outside seems to be buzzing on my air conditioner.It's blowing air but it's not cold" any suggestion before I have to call for service. The air handler is running just fine. No ice build up on unit in the basement.
  • steve
    steve May 11, 2010
    The contactor on the outside unit has failed or the high voltage to the outside is tripped. The buzzing sound is the low voltage coil in the contactor receiving a signal from the thermostat.
    Also, look for ants in the contactor. They will stop voltage from making contact.
    Novelist:
  • 166 Answers
Yes, so as not to be repetitive (as others have had the same problem), here's a simple article that percisely explains the possible causes of your AC not cooling:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Also, if need be, take advantage of the link towards the end for four free quotes from technicians if you find yourself need to get one. (You don't want to needlessly be charged for just someone's coming over only--it could cost a lot for no substantive action.)
Brad
Posted on May 25, 2009
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
18 year old Janitrol Heat Pump freezing up.
i would get someone to check your refrigerant levels have you ever had the evaporator coil flushed and cleaned? proper refrigerant levels and proper airflow across coils are extremley important not to scare you but 18 yrs is a long time on a heat pump 9-12 years is the point where they really loose there efficiency going for a newer one would probably cut your operating cost in half if not more depending where you live there are a lot of people not familiar with heat pumps so i suggest finding a company that specializes in them to service your unit
Jul 30, 2009 | Ruud UBHC Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
