Question about Microsoft Windows 95 for PC
BOOTMGR is missing
When I try to restart my computer I continue to receive this error. I am working with windows XP pro. What can I do. bootmgr is missing how do i fix it!!!!!!
  • 10,515 Answers
Its already solved.Check the solution by an expert -
http://www.fixya.com/support/t411366-bootmgr_missing
Any further help let me know.
Thanks for using Fixya.
Posted on May 24, 2009
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
Bootmgr is missing
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Sep 10, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Dell dimension 4550 Bootmgr missing error message
you would have to removed the hard drive and possibly buy the external adaptor for your hard drive then plug it in to another computer via USB and reformat the hard drive..
Jul 09, 2012 | Dell Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Feb 18, 2011 | Acer Computers & Internet
How to fix "BOOTMGR is missing" in Windows xp
hey Mr Milebdavi try these steps
Apr 23, 2010 | Microsoft Windows XP Professional
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
BOOTMGR is missing
Just had this problem kept getting
"BOOTMGR is missing
Press ctl+alt+del to restart"
and it just cycles through to the same screen. Called tech support and this is how they solved the issue for me in less than 10 mins
turn computer off completely
Hold the "alt" and "Fn" down and power computer back on
While computer is powering on tap the "F10" key
(you need to hit the F10 key on the black screen with the cursor just before the BOOTMGR error appears)
You should get a screen that says "Windows programs Loading"
And then you have to run a restore to factory defaults (this means the computer will work fine once it finishes up the restore, but everything saved on the computer will be lost)
Hope this helps.
Feb 24, 2008 | Computers & Internet
Bootmgr error
theres several stages involving formating a disk.
this error however, appears to be discribing a boot-manager program.
Try booting with Windows in the actually DVD Drive.
If this does,nt work, re-format the hard-drive. or obtain a setup disk from your computers manufacturer.
i.e Compaq.
Mike @ Compurepair.
Feb 24, 2008 | Compaq Presario 2700 Series (222123-001)...
Microsoft Windows 95 for PC Logo
223 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
