Question about Toshiba Satellite A105-S4384 Notebook
Battery dead -
Appears battery is dead- laptop will not run on ACPOWER DIRECTLY
  • Toshiba Master
  • 4,806 Answers
Hi there.
Try removing the battery and using AC power only to boot the laptop.
Please post back if you need anymore help or advice.
Good luck and thanks for using FixYa!!
Posted on May 24, 2009
Nec laptop model
follow this steps and fix it. God bless you
    • 1
Check your laptop's AC adapter. Ensure the laptop's AC adapter is snugly plugged into the port on the back of the . Also, check its connection into either the wall socket or the surge protector, depending on your setup. Make sure the AC adapter is securely in one of these outlets and not loose. Also, if the adapter is plugged directly into the wall, try another outlet. Your existing outlet may be blown.
    • 2
Check your monitor brightness settings. Sometimes these settings get accidentally turned all the way down, which results in what appears to be a dead laptop battery or malfunctioning power supply, but is really just a simple fix. Your laptop has dedicated brightness keys at the top of the keyboard, directly above the numeric keys. Adjust the brightness settings here.
    • 3
Look at the battery indicator light if your laptop appears to be out of battery or suffering a power failure. If it is not flashing or indicating a power problem, your laptop's "LCD closed switch" may be malfunctioning. This switch acts as a sensor which normally judges whether your laptop is open or closed. Sometimes this switch gets stuck in the "closed" position, resulting in the laptop believing it is shut and thus the monitor's back-light staying off. This switch is located right beside either the left or right hinge at the bottom of your laptop's display . Tap this switch multiple times with your finger to attempt to free it up and get it out of the closed position.
    • 4
Consider whether your laptop's battery has completely died and needs to be replaced. Average laptop batteries last for approximately 1000 charges, after which point they either gradual deteriorate and have trouble holding a charge, or simply fail altogether.
Eventually your laptop's battery will have to replaced, and if none of the other troubleshooting steps yielded results this is likely the source of your perceived power supply problems. Flip over your laptop and locate the horizontal outline of the battery, which will be at the top center of the bottom of your computer.
    • 5
Notice the battery release mechanism on the bottom of your laptop, which should be directly below the horizontal outline of the battery. Slide this release mechanism to the left to disengage the battery and gently pop it out. The laptop's power supply may now be replaced.
Jul 31, 2013 | Computers & Internet
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 05, 2013 | Dell Inspiron 6400 Notebook
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
Apr 02, 2013 | Computers & Internet
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
Battery dead after a long run
if your battery dead after a night run you battery charger that charges your battery is not working, and your lights runs directly on your battery with charging it
May 04, 2012 | 1985 Yamaha XJ 700 X Maxim
My sons power pack died leaving laptop with dead battery. small light flashing orange at the front .i bought a replacement power pack making sure it was for his model.plugged it in and nothing it wont...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 25, 2011 | Advent 4211c Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
System shutdown
make sure you are using acpower to install windows
with cd in drive and ac power in restart and choose to boot with cd
then just let it run and on restart after running don't choose to boot with cd just let setup run
please let me know
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Cant run on battery it dies after 5 mins but battery power says i have 99 percent battery and the ac adapter only charges for 5 mins
The Cell on you battery might be dead. if its brand new you need to replace it, might still have warranty.
if not you have to buy a new one in order to run it in battery mode, how ever you can still use it without battery and plug directly at an outlet.
Apr 03, 2009 | Dell Latitude D800 Notebook
I have a laptop gateway computer, the power light is on but everything else is dead, I cannot get the hard drive to eject,all this seem to happen after I got a virus?will this have anything to do with my...
Check all connections mate . Any one of the below could be faulty :-
Power outlet at the wall - try plugging something else into the socket or use a different socket
Are you using any multi-plug adapters? Plug the laptop straight into the mains
Your DC jack may be loose (Where the charger plugs in). This is a common problem and most laptops will get this during their life. Take if to a repair shop to get it fixed. A quick way of checking this is to plug the charger in and wiggle the cord - if the socket where the charger plugs in moves , its a loose jack and it will need to be resoldered.
Dead Battery - Try another battery , or let the battery charge - Try running directly off the mains
Hard drive wont eject? - There not supposed to , the only way you usually disconnect the hard drive is by unscrewing it from the laptop.
How far can you get when you say "Everything else is dead"? can you get to the BIOS? , does anything appear on the screen aty all? If you get a picture but cant boot then its likely that the virus corrupted your windows installation which means you will have to use the repair discs that came with the laptop or another windows install disc to reinstall windows - This will however , lose any documents , music , programs etc that you put on - If you want to keep things off the drive , plug it into another laptop , get all your data back then reinstall into your own laptop. If you rtry putting the drive in another laptop and things dont work and you cant even get your data or the drive doesnt appear , you will need a new hard drive and then have to reinstall windows on the new drive
Dec 30, 2008 | Gateway Computers & Internet
Open Questions:
Toshiba Satellite A105-S4384 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
