Question about Frigidaire Refrigerators
Freezer and refrigerator not cold, temp does not change when settings are changed.
We have a Frigidaire refrigerator with top freezer, purchased 01/05/2002. Model No. FRT18KD3AW2, serial no. BA15123530. The freezer and refrigerator portion is not cold and temperature does not get colder when settings are changed. I'm curious what the life expectancy is for this model refrigerator; whether we should get it serviced or replace it. Thanks for your reply.
SOURCE: Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Posted on Mar 19, 2008
22yooper
  • 828 Answers
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
Posted on May 22, 2008
freetek
  • 5568 Answers
SOURCE: FRIGIDAIRE NOT KEEPING FOOD COLD OR COOL
Higher settings always equal 'colder.' I've never seen a refrigerator/freezer that was in good condition and didn't perform well with the control set to only half of the scale available.
I don't know how old your unit is, or if it has ever been moved, but you may have lost coolant over time or the fan that forces air through the condenser coils under the cabinet may not be running.
You should feel some warm air coming through the front grill while the compressor is running. If you don't, then the coils are unable to dispose of the heat collected from inside the cabinet. These coils do gather a ton of dust over time that reduces their efficiency so you might want to check behind that grill to see how much has accumulated there and carefully remove as much as you can without disturbing the coils too much since they are kind of fragile.
Removing the grill for access is always kind of a challenge but most are held in place by spring clips.
Posted on Sep 25, 2008
ryeisenman
  • 9 Answers
SOURCE: cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
SOURCE: Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Posted on Mar 18, 2009
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
I have a freezer top refrigerator in a rental unit of mine. It is only a few months old. My tenant said the freezer is working fine, but the fridge is not cold. He has tried putting the cold switch in...
Have him put a thermometer in a cup of water overnight and set the upper freezer
knob to the middle position and the temp control to midpoint. The refrigerator temp should
be between 34 and 38 degrees. You can get a thermometer at walmart or an appliance
parts store. If you continue to have the problem then change out the defrost termination
thermostat (this was a common failure in many of my frigidaire units). It is located in
behind the freezer back panel, it is clipped to a tube and has two wires coming to it.
Remember to unplug unit before servicing. The part is under 20 dollars usually.
The model number is located in the fresh food compartment on the left side. Hope this helps
Apr 25, 2011 | Frigidaire Refrigerators
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
I have a side by side gallery, The freezer and fridge are working at the bottom, however, not at the top of the unit. Its like the cool and cold air is not getting circulated to the top of the unit. From...
check the damper door vent as it sounds as if it has frozen itself shut or possibly the cold control in the refrigerator has gone bad and can't control the door,the door is usually behind a diverter panel or a grille where the fan forces the cold air in from the freezer,the cold control is the component that you adjust to change refrige temp setting
Mar 28, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
freezer working ok.
Sep 30, 2008 | Frigidaire FRT17G4B Top Freezer...
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
Refrigerators Logo
152 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
