Question about Frigidaire FGB24S5A Gas Single Oven
Frigidaire oven F-10 error
I have a frigidaire gas oven that will heat up fine but once it's reached temperature an F-10 error will appear. The oven will turn off once the code appears. We reset the oven & turn it back on but within 5min it's doing the same thing & were constantly resetting it to use the oven. I have read my manual but F10 is not liste4d as an error code. It does this more in warmer weather and less over the winter.
Any ideas what this could be?
  • 6,784 Answers
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Posted on Jun 01, 2009
I had the same error message, changed out the temp sensor but the error message keeps coming up....? Is there something I should be doing after replacing the temperature probe?
Posted on Oct 29, 2009
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Why does the f10 code keep appearing on self cleaning fridgidaire oven? When using oven it starts heating out of control. Tends to happen when oven is being used for longer periods of time.
The thermostat is defective. It is a temperature sensor operated switch. It turns the heating element on and off to regulate the proper temperature in the oven at all times.
Jun 03, 2014 | Frigidaire Ovens
Frigidaire es300 bake element
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 20, 2014 | Frigidaire Ovens
Oven won't heat to temperature
Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 03, 2012 | Frigidaire FGB24S5A Gas Single Oven
My gas oven isn't heating up properly, is there
We were able to trouble-shoot our gas oven before calling the repair man. Our oven reached temperature but did not reheat when it cooled down. Our troubleshooting included taking out the storage drawer and looking at the underside of the oven near the valve.
First check if you can see the flame when the oven is on.
Use an oven thermometer in the oven to test if the oven gets to the desired temperature first. Does it get close to the desired temperature and stay near there for your entire bake time? If it does, you may need to adjust the thermostat setting. (This should be in your manual. Many Frigidaire manuals are available from their support site: http://www.frigidaire.com/Customer-Support/Videos--Manuals/ . )
Since our oven was reaching the set temperature and then not reheating, we had one person crawl under the oven and tap on the regulator when the oven needed to reheat. (We could see the ignitor spark.)
If the oven isn't heating at all, then the thermostat, the gas valve, controller or ignitor are suspects. Can you see the spark of the ignitor? Then it's probably not the issue. Similarly if you see the flame coming on several times during the bake cycle, it's not likely to be the valve. If you have a multimeter, you may be able to check the thermostat and controller for any breaks in the wire.
In our case, since the valve was failing, we ended up replacing the 10-year old range. (We looked at the price of a new range versus part and labor cost for the replacement. The part and labor was more than 50% of a new range.)
I hope this helps.
Apr 04, 2012 | Frigidaire Ovens
Frigidaire FGF378ACG won't reach temperature
need to replace Igniter Number: 316119302 its 100$ and few screws...good luck 911servicetoday . com
Jan 01, 2010 | Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven Temperature Probe
It could be your ignitor, if weak it might not be good enough to draw ampage.I would suggest to change both ignitor and temp probe to be in a safer side. part number for ignitor is 12872 $56.0+, Part # for your oven temp. sensor 833085, it should not be more than $28. other part from www.repairclinic.com.
Jul 25, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGB24S5A Gas Single Oven Logo
2,185 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
