Question about Toshiba Satellite A35-S1592 Notebook
HDMI to SHarp LCD
I hook up my laptop to my Sharp 42 inch LCD via HDMI, but it keeps flicking on and off and saying that there is an unrecognized audio signal. I thought I could use HDMI to surf the web with sound through my TV. I have already fooled around with the resolution. Any help?
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Surround sound signal not transferring.
need to go into audio menu and select digital audio as the output signal, its probably set to mts stereo.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Air analog 3 message keeps popping up what does that mean?
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Jan 02, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Help
Best would be hdmi next would be component, both can carry 1080p signal, but hdmi beats component as it can upscale to 1080p.
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Toshiba Satellite A35-S1592 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
