Question about E-Machines eMachines Desktop PC
Deep freeze computer inresponsive
My computer will not turn on one day i came out to try and turn on our home computer and it would not turn on and it was recently having trouble. usually i'd have a fan by our computer cause it had an overheating problem. but this time insted of bieng hot the back of our computer was cold and ever since then we havent been able to turn in on but now we a new one but i still want to figure out how to get our other computer up and running
    President:
  • 688 Answers
It sounds like your computer power supply went bad.
go to your local computer store and buy a power supply, install it and you should be up and running.
that is if you didn't fry everything from running it without the proper cooling.
make sure that you have proper cooling fans in your computer, a fan outside will not do it.
It sounds like your power supply fan stopped working and it just got to hot and died
Posted on May 24, 2009
    Novelist:
  • 152 Answers
Computer componants are very suceptable to hard failures due to excessive heat. When you try to power on the system, if absolutely NOTHING happens, there are several indications that the PSU has gone bad. However some newer computers will not even attempt to activate the PSU if the motherboard / CPU has gone bad.
I would however like to agree with ipodslinger. the first step in determining, and a fixing your problem would be to do the following:
1) replace the power supply unit (PSU)
2) Replace any non-functional cooling fans
3) Try to boot the PC, if fails, step 4 ->
4) Replace the CPU
5) replace the motherboard
If none of these solutions work, it is beyond me to further diagnose the issue with the available information.
Posted on May 29, 2009
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Tip
Install System Restore Software Deep Freeze
Faronics Deep Freeze helps eliminate computer damage and downtime by making computer
configurations indestructible. Once Deep Freeze is installed on a computer, any changes made to the computer- regardless of whether they are accidental or malicious - are never permanent. Deep Freeze provides immediate immunity from many of the problems that plague computers today- inevitable configuration drift, accidental system misconfiguration, malicious software activity, and incidental system degradation.
Deep Freeze
on Jul 28, 2014 | Microsoft Windows XP Home Edition
Tip
Install Restore Software Deep Freeze
configurations indestructible. Once Deep Freeze is installed on a computer, any changes made to the computer- regardless of whether they are accidental or malicious- are never permanent. Deep Freeze provides immediate immunity from many of the problems that plague computers today- inevitable configuration drift, accidental system misconfiguration, malicious software activity, and incidental system degradation.
Deep Freeze
on Jul 28, 2014 | Computers & Internet
How to uninstall deepfreeze?? what can i do?
Deep Freeze is a software that resets your computer to the state where it was freeze. So if you want to uninstall it, here is the way.
  1. First you must unfreeze your computer. Press CTRL+SHIFT+ALT+F6 to show deep freeze. Enter password if you put any password and then Select Unfreeze.
  2. Reboot your computer for the Unfreeze to take effect.
  3. Once rebooted and your computer is now unfreeze, You can now uninstall the Deep Freeze.
Hope my solution help.Please give some feedback regarding my solution.
Thanks for using Fixya!Have a Great Day.
Jul 08, 2011 | Computers & Internet
Uninstall deep freeze, forgot password
If you are licensed for Deep Freeze Standard and have forgotten your password, please email technical support at support@faronics.com for further information. Include your license number and organization details.
If you are running a 60 day evaluation version of Deep Freeze and have forgotten your password, then enter the computer s BIOS and forward the system clock 60 days & restart.
I hope this helps, if it does, give me a big thumbs up!
Jun 28, 2011 | Computers & Internet
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
For Deep Freeze evaluations (with no License Key entered):
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
To disable Deep Freeze:
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
2. Enter your password and click OK.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
I cant install new version of my anti virus
you need to install deep freeze again. After installing, restart the computer and uninstall it.
hope this will help!
Peace!!!
Dec 26, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
144 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
