Question about HP Pavilion zd8000 Notebook
Video capture I have an HP zd8000, touted for its rapid-fire video capture. I can not get it to capture video at all. I have an s-cable out of my DVD/VCR machine into my s port on the xb2000 expansion base, but it is not showing up as a video device on my computer. I can see the video on my computer, but can not capture. Any ideas?
Is there a product available that will allow me to convert VHS to DVD using my HP desk top as the tool?
you will first need a video player,then a product called "video capture" will plug into the usb port and has the 3 video wires on it ( usually red,white and yellow). simply plug the vcr into them wires. heres a link to the type of capture device you will need.
https://www.google.co.uk/search?q=video+capture+card&es_sm=122&source=lnms&tbm=isch&sa=X&ved=0CAgQ_AUoAmoVChMIusaljMyOyQIVgroUCh2KUwSj&biw=1366&bih=643#tbm=isch&q=usb+video+capture+card&imgrc=_
hope this helps
Nov 13, 2015 | HP Televison & Video
When I try to capture a VHS feed, importing from video composite, I get the message saying "no input signal". My VCR is old. Is it possible that this is the cause, or are there other things that I should...
Likely the VCR is unable to function properly anymore, however it would not hurt to check the cables. Some cables when they get old develop shorts in the wires this is also a probable cause. Try new cables first then a new VCR.
Jan 23, 2014 | Pinnacle Dazzle Video Creator Platinum...
I get a tracking error code when trying to write to a CD. I don't have the code number with me, but it ends with 1h. The program I'm using is Cakewalk Pyro and I'm converting a tape to a CD. ...
so what CD??? CD-R recordable, CD-RW?
No PC stated. NO OS stated ,wow.
just DC3000 and some kind of VHS tape?
My guess bad media. (CD-r)
or the drive it self is bad.
or as all XP are , virus infected,
the spec says
Transfer, edit and burn home videos with this all-in-one external HP DVD movie writer. The built-in analog video capture lets you quickly and easily transfer home video directly from tape to DVD via your camcorder or VCR, while the included suite of software lets you add special effects, music and more to video and photos. Also great for creating music CDs, it writes and reads CD-R and CD-RW discs in addition to DVD-R and DVD-RW discs. Includes software CD, electronic user's guide, USB cable, composite video/audio cable, 1 blank DVD-RW disc and 1 blank DVD-R 4x hi-speed disc. Requires a PC with Microsoft Windows XP or 2000 Professional SP2 and USB connectivity.
Nov 05, 2017 | HP DVD Movie Writer Dc3000 DVD+RW Burner
How do you transfer video VHS to DVD?
I'm glad to provide the instructions to transfer video from VHS Tape to DVD. You may purchase a DVD Recorder and connect the VCR to its A/V input to record the videos directly to a DVD. There are VCR/DVD Combo Recorders available where you can dub from VHS to DVD without using another VCR.
Alternately, if you have an A/V interface in your Computer, you can connect a VCR to the Computer and capture videos using Windows Movie Maker or any other video capture software. Once you transfer the video to the computer, you can burn the videos to a DVD using the DVD burner in the Computer.
Thanks for understanding. Please let me know if you require further assistance or any clarifications.
Thanks for using Fixya
Aug 08, 2011 | Televison & Video
We have VCR tapes with videos on it we would like to convert them to DVD or CD- how should we do it
I hope that you have plenty of time on your hands. If you do, then you will need a video capture card or tv-tuner USB dongle. Most large computer stores carry a variety of choices. Hook the line-out of the VCR to the TV-tuner or video capture card and use the digital video recording software that came with it to record your video to your hard disk. From here you can edit it with a video editing program and burn the finished product to your DVD or you can burn the raw files to the DVD.
Sep 13, 2009 | HP Pavilion dv5020us Notebook
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
I need a picture of how to hook up the dazzle to the vcr
If your trying to capture from a vcr make sure that the cables "composite are connected at the back make sure it is plug in to the video out.
Next, connect the cables directly to the dazzle.
make sure that the vcr is on and it is playing.
In the program Instant DVD Recorder please go to the step 1 select the dazzle as your video source not pinnacle file capture.
Then click option check the VHS input.
Video input must be composite if your using the composite
Audio input must be the dazzle.
Jul 04, 2009 | Pinnacle Dazzle DVD Recorder
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Saa 7130 has no video
try to connect the antena or the cable in to a vcr, cable box or dvd player and then from the receiver connect the card with compositive the yellow cable. After is install click on the compositive buttom on the program. Remember that you may have to click on the auxiliar or input buttom on the vcr, cable box and Dvd player
Aug 02, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
HP Pavilion zd8000 Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
