Question about Insignia IS-LCDTV32 32 in. Television
Large black box appears in center of screen with date and other numbers on it. Push any button and it goes away for short time
Its 2 years old, have large black box appears in middle of screen with date and other numbers on it. Push any button and it goes away for short time
    President:
  • 814 Answers
You can try resetting the television controls by unplugging the television from the power source for a few hours. This means physically removing the power plug form the source of power. This may allow the controls to reset out of the latching position they are in now. If this does not help, you are having a problem with the main board.This board is master control for all the televisions functions,like audio, video and switching controls. You can call the Insignia customer support at this telephone number. 1-877-467-4289. Give them the model number of your television and ask them how you can find service for it. You can also use the customer support website. www.insignia-products.com. go to the customer support section and ask them for help with your problem. I hope this information helps you with your problem.
Posted on May 25, 2009
Black box on screen
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Feb 12, 2010 | Sharp LC-19SB14U 19 in. LCD TV
Black box in middle of screen
go into the menu and turn your closed captions off or if there is a cc button on your remote you can turn it off that way.
Sep 08, 2009 | Hitachi 57F500 57" Rear Projection...
I need to set time n date. I have no manual. How do I set time & date?
power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
Jun 26, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Black box in center of screen
The Panasonic call center helped us with this one. Our Closed Captioning had been turned on through the TV settings. This made us have a black box with everything besides our cable. Turning off CC on our TV Main Menu solved the problem for us.
Jul 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black Box on Screen
that can be TXT i mean teletext button can be activated and you should turn off your TXT by pussyng Tv button on your remonte control
Jun 20, 2008 | Sanyo AVM-2556 25" TV
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Insignia IS-LCDTV32 32 in. Television Logo
110 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
