Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
Bolt hangs up
Lock is in a house on the beach, some pitting noticeable on the bolt. Bolt does not "throw" all the way using the thumb latch, but is free to move and will move the whole way if helped by grasping it and pulling. Might this be corrosion of the latch pawl or some other part inside?
  • 323 Answers
Likely both. Spray liberally with rust penetrator. After it dries out some, spraying white lithium grease in it would make the lubrication last much longer.
Posted on May 24, 2009
How do I remove the plastic starter housing?
You have 3 options: drill out the bolt that is stuck. Break the housing below the bolt ( remove housing,Get a washer big enough to cover the "Bigger"bolt hole and use the same bolt).Take it to a shop. If I was there I could fix it,If you striped the bolt head ,you might try a pair of lock pliers to remove the bolt.
Good luck,Sandy.
Oct 24, 2015 | Garden
Rear door hang
move the post on the body inward to tighten the seal the latch has worn use chanel lock pliers to lossen it its just a bolt then move it inward n retighten it
Mar 14, 2012 | 1994 Cadillac Seville
How to remove ingition housing from steering column
Welcome to Fixya
Thank you for bringing up the problem to our attention. To serve you better, could you please provide me the exact year model of your car.
Your response will be greatly appreciated.
Thank you for using Fixya!
Aug 26, 2011 | Saturn Ion Cars & Trucks
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do you replace the thermostat on a 2007 Buick Terraza?
Hi!!
Engine Coolant Thermostat and Housing Replacement, Tools Required: Hose Clamp Pliers.
Removal Procedure IMPORTANT:Use the hose clamp pliers to gently release tension on the hose clamp until the hose clamp lock feature engages allowing removal of the hose.
Fig. 1: View Of Radiator Inlet & Outlet Hoses
  • Drain the cooling system.
  • Using the hose clamp pliers, release the tension on the hose clamp at the thermostat housing and reposition the clamp.
  • Remove the radiator outlet hose from the thermostat housing.
Fig. 2: Identifying Thermostat Housing & Bolt/Stud
  • Remove the thermostat housing bolt/stud.
  • Remove the thermostat housing.
INSTALLATION
  • Position the thermostat housing.
  • Install the thermostat housing bolt/stud.
  • Tighten: Tighten the bolts to 25 N.m (18 lb ft).
  • Install the radiator outlet hose to the thermostat housing.
  • Using a small flat-bladed screwdriver, release the hose clamp retention lock at the thermostat housing.
  • Fill the cooling system.
Good Luck and Merry Christmas!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 17, 2010 | 2007 Buick Terraza CXL Wagon
Can't open liftgate on my 95 jeep grand cherokee
unscrew all the screws and pull the top of the panel away from the glass. then reach down and pull the latch mechanism that the handle normally does. that what i had to do. its a little tough but it saves the panel. just remove the panel till you get it fixed.
Mar 08, 2010 | 1995 Jeep Grand Cherokee
I have a 1996 Mercury Mountaineer. Sometimes the drivers side interior door handle does not open the door. It moves but ti does not open the door. This is a on again, off again problem. Is it connected...
no the latch could be hanging up, the keyless entry pad has no mechanical connection, lube the latch area generously, ....even pull the highest bolt holding the latch in place and with the red nozzel spry into the bolt hole .....hold handle in up position and close door like ten times or more to work the lube into moving components....... make sure when this happens that the lock is fully rising to allow to open,
may need and actuator also if thats not occuring.
Jan 21, 2010 | 1997 Mercury Mountaineer
Door knob to garage won't open. The "bolt" won't retract.
If all else fails...take pins out of hinges and remove door to get to lock bolt.
Sep 07, 2009 | Amerock 3 Ring Knobs - BP1586
2005 sunfire trunk won't close and latch
this happened all the time on my 03, take two plyers, one in each hand and put them both onto the u-bolt (the part that the latch latches to) and pull up then try and close the trunk, sometimes the latch pushes that ubolt platform down so it cant grab
Jul 01, 2009 | 2003 Pontiac Sunfire
1999 gmc suburban, door lock won't unlock
You need your door lock actuator's replaced because they are sticking.
Apr 09, 2009 | 1999 GMC Suburban
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
149 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
