Question about Nokia N73 Cellular Phone
2 number not working properly - Nokia N73 Cellular Phone
    Problem Solver:
  • 10 Answers
Either the wire came off the Number 2 button keyboard or it's not making a connection
Posted on May 25, 2009
Brother DCP-195c error prinr unable 73
Sir/Madam
I suggest You Go to Official Brother Printer trouble Page For You Brother Printer Problem On Below Brother Printer forum URL Link:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000095/faq000495_033.html?reg=eu&c=gb&lang=en&prod=dcp195c_all&Cat=11
I Hope You resolve Your Brother Printer Issue,
OR
In case You Need Online Assistance Then follow Us For ON:
Brother Printer Support
Feb 01, 2014 | Brother DCP 165C Compact Color Inkjet...
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Wireless guitar does not work properly
Look for a phone number and phone it I think it may not be connected properly
Nov 14, 2011 | Psyclone Wireless Budokan Guitar for...
My toshiba A600 S6050 webcam is not working
If the webcam is not working then it means it doesn't have a proper driver to work properly.
So in order to work properly the camera you need to see the model number and after that search for the driver and download it and after that re-boot the system.. After that it works..
Still not working it may be having problems with the Laptop.. So contact the Toshiba Shop from were you buyed,...
Thanks
May 21, 2011 | Computers & Internet
M USING 1600 NOKIA MOBILE PHONE BUT SOME TIMES I CANT SEND MESSAGE.
Welcome to FixYa
  1. Check you Properly inserted SIM[Working SIM]
  2. Ensure you are in Sufficient Range/Phone in Network Signal
  3. Check you have Enough Balance to Send Message
  4. Some times Network/Message Server MAY DOWN[Contact your Provider]
  5. Properly Configure Message Settings
Go to
  • Menu
  • Messages
  • Message Settings
  • Sending Profile
  • Message centre Number
  • Enter Proper Number[Proper Number will Get by Contacting Customer Care Center/From Your Network Provider-It means this number Different in Different Providers]
Here is also Guide for Your Product Click..
Now your Problem Solved....You can feel free contact me...If this Helped -Rate ME..Thanks for Contacting FixYa...
Jun 29, 2010 | Nokia 1600 Cellular Phone
I have to unplug and replug the router to get online
If you connect the computer directly to the modem
does it work properly.
If that works properly then your modem is working
properly.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Water pump is leaking and causing the engine to overheat. The pump has been "repaired" what shall i do now?
obviously the water pump was never fixed properly if it is still leaking, take it back to were you had it repaired and have them repair it properly. A number of problems could cause your vehicle to over heat.
-water pump not working properly.
-low antifreeze.
-air lock.
- rad cap not working properly.
-thermos stat not working properly.
Aug 14, 2009 | 1992 Honda Accord
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
