Question about Crown CE1000 2-Channel Amplifier
Crown CE1000 the right channel on my amp is not working at all
  • Jango Fixit
    Jango Fixit May 11, 2010
    Look behind the amp. Is the mode switch set to stereo or bridged?
    Jango
  • 54 Answers
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
BigRED
Posted on Nov 03, 2007
Clip led
That particular channel is blown. These are not the easiest units to repair. Given that this is a commercial amp, I would recommend that this unit be brought to an authorized Crown service center for repair. Expect parts cost in the $50 range plus the labor charge.
Dan
Apr 07, 2008 | Crown CE1000 2-Channel Amplifier
The fan on my CE1000 does not come on when the amp is powered up. The amp seems to be playing normally, but I am afraid I may over heat the amp if the fan is not working. Is this normal?
The Thermal Senser on the Heat sink may be Defective. Heat the Thermal senser and see if Fan Turns on. It is a device with 2 screws holding it to the heat sink
Oct 07, 2010 | Crown CE1000 2-Channel Amplifier
Fan running
Yes, many of the pro sound amps throttle the fan based on an internal temperature sensing device.
May 14, 2010 | Crown CE1000 2-Channel Amplifier
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
Fan running
This is a very sophisticated amp and it will turn the fan on at various speeds when it feels the need for it. Of course, if it's running REALLY hot, going into thermal protection and/or posting a fault you might take a look at it to see if it CAN turn (no obstructions).
Mar 26, 2010 | Crown CE1000 2-Channel Amplifier
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
I need to send my CE1000 crown amp in for repair.  Where can I send it?
Typing "amp repair" in google should get you a fairly comprehensive list.
I fixed a couple of my amps recently which had blown transistors. These were pretty obvious to spot (look for scorch marks on the PCB) and only a couple of £s to replace - significantly cheaper than a professional repair job, it just depends weather you have the courage to do it yourself!
Jan 24, 2009 | Crown CE1000 2-Channel Amplifier
Crown CE1000
Hi waveybnc
The fan has failed, or is clagged up with dust. Remove it and clean it first. But best to just replace it. They are not that special and there is not alot that stops them from working. You can get a replacement device for the amp from Crown direct, or once you know its dimensions and power requirements, from here.
Thanks for using FixYa. Please rate my advice to you here as FixYa if it helps you.
regards
robotek
May 25, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
169 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
