Question about Garden
Weed eater spool fell off
Several strong strands of a plant wrapped themselves above the weed eater spool. When I restarted, the spool fell off. I didn't find any metal item that may have held the spool onto the shaft.
  • CDFCPAMAN May 24, 2009
    Homelite Bandit SX135, model UT-20601. I do not know how it was connected previously. I remember disconnecting it one time to grease the shaft but I cannot recall how it was connected. I looked on the Homelite website but could not find an answer.
  • Dan Todd May 11, 2010
    Without knowing exactly what brand you have and how it is fastened on, I would think you have tabs that come through slots and hold it on. Can you supply more info about how it was connected?
  • 50 Answers
The spool goes on first then a big spring and finally the cap and the screw thats all
Posted on Oct 16, 2009
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
How do I load the string?
Hi j_janes....
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker String Trimmer Cordless 12"...
Line installation
Hi bluemontel52...
Hi
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to replace string on te475y
Hi jtl91370...
Try this solution...
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
I like to know how to wier the line om my poulantrimmer model ppo25\
Hi rlgingas...
Some you will have to remove the center knob.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How do we add line to the trimmer?
Hi jeff clar0
Jul 01, 2011 | Husqvarna 28cc Gas Line Trimmer
Poulan PL 25 plastic cord replacement
You can buy bulk cord of the correct size and re wrap the old spool. Or, go to walmart and buy pre-wrapped spools.
Mar 15, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I just bought a craftsman weed eater and the fishing line gets caught up and wrapped around the spoke of the turning mechanism in between the the covered spool and the machine. How can this be fixed. Is...
it is very hard to rewrap the line in any weed eater. Techs get paid good money to do this, and there is a spring that must be placed inside the spool container that gets pressed to release new line. My suggestion, if is giving you this much trouble, and, will every time it needs new line. remove your old spool and go to the hardware store and purchase a spool that has plastic or metal blades on it. ie, no line, nothing to wrap, nothing to feed. Just be careful using it and do not let a child near it, it will nick you. They are less than 20 bucks and alot cheaper than getting a technician every time it needs to be rewound. I worked for sears and we saw these every day. If you must have the line. follow the steps in the manual step by step, it does take some force to get the spool back on properly, because of the spring. just make sure you direct the recoil away from you or your body at all times.
Jun 11, 2009 | Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Garden Logo
395 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
