Question about Samsung 710V 17" LCD Monitor
Samsung 710V - controller box
My Samsung Syncmaster 710 V only displays white screen. I've tested the screeen itself by removing it to another LCD, and it works fine. The power supply also has no problem. But when i connect it to the controller nex to the internal power supply it shows me the same white screen. What is the problem and what should i do?????????????
  • 151 Answers
Your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Posted on Mar 04, 2008
Hi I have SyncMaster 710 LCD monitor I have windows7 now what settings i must use?
dear you use the screen resolution for windows 7 (1024x768) for best display and use the text display smaller in display text settings.
Jan 20, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
All I get is a white screen
copied from http://www.fixya.com/support/t190380-turn_screen_displays_white
I have a Samsung Syncmaster 175v Mfg Oct '03 displaying the __ White Screen . I removed the screws on the back , removed base stand, separated case with flat screwdriver starting at bottom, unplugged the small wire to the panel menu buttons , removed metal cover from back of LCD. Now you can see the powerboard \ inverterboard combo and the attached video signalboard. Follow the 30 wire plug to the LCD screen, the 30 wire plug goes under a metal panel , remove the 3 small screws securing the panel and you will see the hidden LCD screenboard. Very close to where the 30 wire plug attaches to this screenboard on the Rightside you will see with a magnifying glass a SurfaceMounted Fuse named F1 with a value? of "K". On my LCD the fuse tested with a volt-ohmmeter to be Open or Blown. The right thing to do would be to replace the fuse however I acquired my LCD from a trashcan / dumpster so I stretched a drop of solder connecting both sides of the fuse. Now I do not have the protection from power failures and surges that the fuse could offer but upon reassembly my screen works like new again .
PS : i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 18, 2008 | Samsung SyncMaster 175V 17" LCD Monitor
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Turn Screen on and it displays white
Aug 30, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
220 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
