Question about Kenmore 46462 Front Load Washer
Grease/dark spots on 'clean' clothes
Have had my front loading washer for 4+ years and never any trouble. All of a sudden the loads are coming out with dark/greasy spots. Some are long smears and others are spotted patterns that mimic the pattern on the inside of the tub.
HELP. My husband took a look at it, but didn't see anything. It seems to me that there is a bearing leak or something similar. It has also gotten louder during the spin cycle.
    Sergeant:
    Novelist:
  • 176 Answers
This is a cronic problem of front loader machines. The two bearings that hold the wash drum are dried out and then they over heat. The heat build up weakens the seal that keeps water in and grease out starts to leak and the problem just becomes worse with every load. A service repair man will charge you the cost of a new machine to fix the unit. You can replace the bearings and seal with parts from a bearing supply store and if you do, only use bearings from Japan or Germany. Your machine came with ones from China and that is why these machines are failing after 4 years.
Posted on May 24, 2009
Clothes comes out with spots. looks like grease spots.
the valve is lose or better still u hot wash it 4 10 -20 minutes then u spin and check it again with old clothes, then if it continues the valve is lose some where in the washer
Jul 06, 2011 | Kenmore Elite 45986 Front Load Washer
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Grease Spots
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 25, 2010 | GE WSXH208A Front Load Washer
We've had our machine about 6 years, and it is spewing dirt back onto our clothes, is this a typical problem for this machine? How do I make it stop? My clothes go in looking clean and come out with dark...
I assume you have run the machine several times empty to try to clean anything forign out of it and had no luck .
Sounds like a transmission seal letting grease into the washer.
I would call for service.
Sep 19, 2009 | Kenmore 44072 Front Load Washer
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Dec 13, 2008 | Washing Machines
Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Sep 28, 2008 | LG WM2487H Front Load Washer
Kenmore 46462 Front Load Washer Logo
463 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
