Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Blue screen with white snowy circle in the middle of screen
TV was working fine, turned it off.  Later when I turned it back on the screen was blue with a white snowy circle in the middle.  There is no signal to the tv.  Direct TV thinks it may be a tv problem.  Does this sound like a problem with the tv or maybe a cable?  Reset everthing and switched around a few cables with now luck.
  • 4 more comments
  • nealman Nov 20, 2007
    blue screen, pulsating whitish ball with wings in the center of the screen, no sound, no nothing!
  • Anonymous Jan 06, 2008
    yes and my lamp light come on
  • x2gthoma Jan 06, 2008
    Blue screen and lamp ligth red, with white snowy
  • adlorl Feb 07, 2008
    I have the same problem except it says to check the power or that the RGBHV or YPrPb inputs my be invalid. I help the menu and device buttons down and got a 12 code....doesn't that men no problem?
  • debivanomen Jul 11, 2008
    I have this same problem!
    How do I get documentation on the TV so I can find the right board
    and identify the right capacitors to replace?
  • redfox5878 Sep 05, 2008
    We have the same problem with our WD62525. Had a repairman out from American Elec. & App.. He tells us we have a bad optical block and a bad chassis(capacitors are drying up.) Quote us 1500.00 on a 3 yr. old tv that cost us 4500.00. Suggested we try to go back to Mitsubishi and ask for help with repairs. We did so and are waiting to hear back.
    President:
  • 4,402 Answers
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Posted on Dec 19, 2007
SOURCE:
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Froze blue screen
software fault take to a mobile shop to reflash
May 28, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Blue circle of color in middle of screen
This is your Light Engine that is defective. They usually cost in excess of $700.00 to replace. Not the Lamp.
May 02, 2009 | Televison & Video
Blue circle across top of tv screen & maybe some yellow
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Jun 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Colored Circles
sounds like the degausing coil isnt working or you have a speaker close by.
Dec 04, 2007 | Panasonic CT-36D32 36" TV
Light Blue Circle in Center of the Screen
Hello BruceD,
What you may have is a magnetism problem. I would suggest that you try deguassing the CRTs first before looking into replacing the CRTs. You can have a TV technician perform this for about $50.00 - $60.00.
Thank you,
Shuttle83
Oct 27, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
