Question about Compaq Presario C700T Notebook
My notebook is running hot and freezing up
My computer is running hot as soon as I turn it on and then it will go to windows and be okay I can even open a file but as soon as I do it tells me the computer is not responding. I finally after 2 hours got most of my stuff onto a flash drive but it still is doing it. but it doesn't want to work. what is wrong with my computer?
  • 331 Answers
Is the fan working on the back. you should be able to hear it.
Posted on May 24, 2009
Dell 8100 dimension keeps freezing
I need more than that to tell you how to troubleshoot the problem you're having. Most freezing or locking up is caused by a program not functioning properly. Start your computer in safe mode. Go to your start button, type in the search RUN right click and run as Administrator, then when the box opens type in MSCONFIG and click run/yes/okay (which ever you see). This will bring up a new window. On the main tab you'll see three options. Normal start up, Safe Mode, and Selective Startup/Custom Startup. Click safe mode hit okay and it will restart the computer into Safe Mode. This will prevent all startup programs and services from starting. Let the computer run and if it still freezes then you know it's a hardware issue. If it doesn't, it's a program error. Take the time then to diagnose either the hardware or the software. If it's the hardware, check to make sure that everything is seated correctly, that the ram is firmly and fully in their sockets. Make sure your hard drives are connected correctly. Check the power supply make sure it isn't dying and causing you too lose power.
Look at the motherboard and check for heat damage, blown resistors and other components.
If it's software, go back into MSconfig, go into selective start up and choose one or two programs at a time and restart the computer until it freezes. If you get it to freeze with a specific program you know it's the culprit.
Also, freezing tends to be related to bad configurations. I dont' know if you've been trying to overclock the processor, the ram, or the video card (onboard or dedicated) could also cause these issues. Check your bios and make sure your settings are correct. Stop using any overclocking software.
Lastly check temperature. The normal operating temperature of a desktop PC is 130 degrees F with some of the more powerful processors and video cars. 90 degrees F while not under load. If your temperature is getting too hot it could be crashing. This could indicate a bad processor, a heatsink that isn't seated or in contact with the processor anymore, malfunctioning fans, poor circulation, or even dust/grime/dirt getting into the computer.
You could be experiencing this GUI lag or freezing if you have background processes that are taking priority over it while they run drawing more of the computers resources. Let it sit for a little big and see if it corrects itself.
Lastly, if you're getting blue screens of death because of windows, get the logs for them and post them so we can go over them and see if anything else is happening.
Oct 16, 2013 | Dell Computers & Internet
My computer wont start
If it doesnt start,make sure you hear the power supply turn on.if no noise at reboot,replace the powe supply
Apr 12, 2017 | HP Pavilion dv9925nr Notebook
When I turn my laptop on everything seems okay. As soon as I click on anything it freezes up, and will not unfreeze.
You may have a virus on the machine or another unspecified windows (assuming it's Windows) issue.
I would reccomend testing in Safe Mode.
- Turn off.
- Tap F8 immediately after switching on.
- Choose 'Safe Mode'.
- Test.
If it works ok there, then you may need to reinstall windows.
If still freezing, then you may have a hardware issue. Some further tests like HDD/Memory tests may be necessary.
Apr 26, 2011 | Computers & Internet
I have an Acer aspire one netbook. As soon as i turn it on, it shows the first screen that is black with ACER on it, but it just freezes there. I can't access the computer unless i press F2 and exit setup....
Looks like there is something wrong with the registry database of your computer. Best way to fix is to clean Windows registry using some reliable software such as Reginout and start your computer normally. Also do the following.
> Limit your startup programs
> Uninstall unwanted programs
> Disable background running services
Thanks
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
Turns off when it gets hot
it is the issue with the processor please consult the manufracturer for the replacement of the processor or soon the computer will boom
Sep 15, 2009 | HP Pavilion dv9000z Notebook
Computer Freezes unless pressure applied
With the laptop turned off, take out the hard drive completely from the laptop and then reseat it back into its slot and make sure its nice and snug.
Then go ahead and turn it on and see it will run without freezing on you and having to apply pressure on the keyboard.
If that doesn't work then disconnect the keyboard and see if it will run smoothly without the keyboard. If it does then you might have a stuck key on the keyboard that is making the unit freeze so you might have to replace the keyboard.
Jul 06, 2009 | IBM ThinkPad T43 Notebook
Hp dv6000 freezes
ok
when you power up the computer press F8 key then enter in safemode.
Then go to start menu then run type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.wait until it load windows .
Ifyou stillface problem then your computer is virus infected scan your computer in safemode with good antivirus.
Jun 23, 2009 | HP Pavilion dv6000z Notebook
My laptop freezes in the middle of doing anything therefore I cant get anything done.
run a spyware removal program on the computer and see if that helps. also what is the make and model of the computer as well as the operating system you are using
Dec 16, 2008 | Acer TravelMate 2300 Notebook
Frozen Toshiba P100
Try This. Restart your computer and as soon as it boots up tap the F8 key repeatedly until you see windows advanced options menu. select safe mode. when it asks you for the operating system just hit enter. as soon as it boots to safe mode do this. click start> run> type msconfig then hit enter. On the system configuration utility click on the startup tab then select disable all. Click apply then close. restart your computer again. It may be a corrupted startup program that is preventing your computer to boot up properly.
Oct 08, 2008 | Toshiba Satellite L25-S119 Notebook
IBM T22
Does it feel like it's running hot? If so, check that the cooling vents are clean and that the fan is running. A second thought is that you may have some mal-ware that you've picked up off of the internet. I fought a similar problem on an IBM T41 for several weeks. Look up and download a copy of Ad-Aware SE (it's free!) I wouldn't have a computer without it installed. Picks up all kinds of crap that Norton never even sees. Same to be said about AVG, and that's free, too.
If this tips don't solve your issue, get back to me and we'll pick up from here.
Ron-
Nov 09, 2007 | CMB T43 750 Notebook
Compaq Presario C700T Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
