Question about Dell Dimension 2400 PC Desktop
Loose keyboard connection
I have a dell dimension 2400. the keyboard connection is loose and i need to change it. my keyboard is working but only sporadically. i can see and feel the looseness in the connection.
HOW DO I DO THIS?
Thanks
cyberfry
    President:
  • 948 Answers
You will have to either repair the connection with a soldering iron, replace it (which means finding a connector from another board and desoldering that one, then desoldering yours and installing the good one), or simply change to a USB keyboard.
By far the easiest thing to do is change to a USB keyboard. You could also use a simple USB to PS2 converter if you don't wish to change keyboards, the converter would simply allow you to plug your keyboard into a USB slot on your computer.
Posted on May 24, 2009
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 keyboard and mouse and monitor not working
i think its a hardware issue so you should contact to dell care..
May 05, 2012 | Dell Dimension 2400 PC Desktop
Keyboard failure on dell dimension 2400
Your keyboard needs to be pluged into one of either a USB port, if it has a USB connection or a PS2 Port if it has a PS2 connection.
USB is the rectangular shaped port, while the PS2 is a round, usually purple coloured connector.
Try pluging it in and out, with USB connection type try another USB port at the rear of the chassis or on the front too.
It is possible that the keyboard is faulty, in other words it has come to the end of it's life. Meaning that you may need another keyboard.
Try this keyboard on another computer, a friends computer will do. You could even try a friends keyboard in this computer as another test.
Take care!
damnor01
Jul 04, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't power up?
It is possible that you may have a bad power supply and need to have it replaced, it could also be something simple such a a loose connection on your motherboard. I would start out by removing the power supply from the machine and having it tested at a computer shop. Also make sure everything is plugged in correctly on the hardware. Let me know if this helps please, Jeff from fixya
Jun 15, 2011 | Dell Dimension 2400 PC Desktop
Hard disk 0 configuration error post error keyboard error dell dimension 2400 xp
Unfornate motherboard failure. Ran into many with the same problems. The usb ports fail, then the ps2's,etc. Needs a mobo.
Apr 11, 2011 | Dell Dimension 2400 PC Desktop
When typing the keyboard hesitates and skips letters.
Turn the computer off.
Disconnect your keyboard.
Connect a different keyboard.
Turn the computer on.
Try using the alternate keyboard.
If it works properly, then you have a solution.
Jul 17, 2010 | Dell Dimension 2400 PC Desktop
Keyboerd failer when starting
try to change the mouse or keyboard from serial connection to usb, or likewise, might be both of them are conflicting..if both are usb...also update the drivers, try it.,,
Nov 10, 2009 | Dell Dimension 2400 PC Desktop
On booting up, computer can not load keyboard system.
One possible problem is that your PS2 keyboard port at the back of your PC is ruined. In time, those so called "outlets" become loose specially the ones with cables which usually got pulled or tangled and make the port strained and the contacts get loose.
If that is the case, you might need to replace the keyboard port, or just stick with your usb keyboard.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400
a computer proffesion dosent need a mouse to wok on computer . the windows (logo) botton opens the strt menu . then scroll it with up and down arrows press enter to select . tab to switch between windows and drives . windows key+ e opens my computer . windows +d reduces windows
Dec 23, 2007 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Dec 17, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
