Question about RCA D52W19 52" Rear Projection Television
My rca d52w19 will blink, but not come on.
My tv shut off and will not come on, but will blink. I replaced the flyback, and the same problem with the blinking. Can you help?
Thank you
    Genius:
  • 1,139 Answers
Hello ,
I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
I have a RCA d52w19. when I turn it on, the LED flashes 3 times and shuts off. Basically the same problem as everyone else. However, I changed CP150, CP120 and CP114 and still have the same problem. What...
if you replace the bad cap,s cp114 cp150,cp120 and still give you flashes 3 time you do have a bad flyback 21.40 for the flyback but in the same fix you see 3 fuse by the flyback hit them with solder thay is the power supply for the conv, borad.i work for quaker tv i seen a lot of that d52w19. you mite whant to look at the power wire that go to the front buttom con,t in front of tv if thay are pich in eny way the set will not come on. but you have a bad flyback.
Dec 07, 2009 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Tv turns on then turns off
you need to replace the flyback its the 259296 flyback which is available at the following link and they send free instalation instructions with detailed photos on how to do the replacement of the flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-flyback-259296/cName/flybacks
Feb 27, 2009 | RCA D52W19 52" Rear Projection Television
Tv not turning on
replace the flyback you need flyback # 259296 you can get the flyback at the following link with free installation instructions.
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
Aug 22, 2008 | RCA D52W19 52" Rear Projection Television
Turning on tv
try resoldering the flyback, they are famous for bad solder connections as well as bad flybacks.
Jun 24, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w19 chassis itc222
You need to replace the flyback its flyback 259296 and you can get a new replacement for 47.99 at the following link.
Jun 06, 2008 | RCA D52W19 52" Rear Projection Television
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
167 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
