Question about Troy Garden
I changed belts on mower and now it will barely go no matter how hard you press pedel
I changed belts on my mower a 20 hp 46 inch and now cant get any speed out of it
  • 4 more comments
  • rjdreas May 24, 2009
    the model # is 13cu609h063
    got the belts from troybilt .com
    no the belt wasnt broke it was frayed bad I have checking the routing serval times but not sure of the belt numbers
  • rjdreas May 26, 2009
    I got it thanks it needed to be tighten more thanks for you help
  • Dwain Pippen May 11, 2010
    Assuming you got the #'s 954-0467 (lower) and 954-0468 (upper) for belts, have you checked the routing through the ider pulley assy that pivots when you push the pedal to make it move? Possilby have the belt routed backwards? Also, above the idlers assy., there is a short bolt and spacer that bolts to the frame (out of sight) and separates the the two sides of the lower belt. Was the front belt broken when you took it out?
    You either have the belts routed wrong or the incorrect belt(s). what is the model # under the seat?
  • 376 Answers
I know I've said this already, but where the right side of the lower belt goes through the two idlers, it is possible to get that routing backwards which would not properly tighten the belt when you push on the pedal. And, you never said if you removed and replaced the short bolt above the idler assy. That bolt has to come out when replacing that lower belt because the belt has to go on either side of it. Have you pushed on the pedal while watching the idler assy. to see if it tightens the belt?
Posted on May 25, 2009
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a yard machines 46 inch cut 18.5 hp riding mower that wont start. i changed ignition swith and soleniod. if i cross wires on solenoid it will start after putting gas in carb. it runs till gas runs...
I would start with the safty switches. Look for them on the deck engager, seat??, break/clutch pedel,blade engager lever. Remember the blade sw. must be disengaged be fore it will start. Ifit runs as you said It is in the wiring/ electrical system. I know it is not in the ignition sw. or seloniod. szm230
Apr 15, 2011 | Yard Machines Garden
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
My craftmans 46 in cut (22 hp) tractor goes backward after I changed drive belt
If you notice how the belt leaves the motor pully and goes to the transmission, it makes a 1/2 twist? Well reverse that twist and the tractor will go in the correct direction.
Jul 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I RECENTLY CHANGE THE DRIVE BELT ON MY 46 INCH
Recheck your installation, make sure you have it routed correctly and it is good and tight when in gear and the clutch/brake released. Check this with the engine OFF and the spark plug wire disconnected
Sep 18, 2009 | Garden
Belt diagram for craftsman 46" model#917258691 I am replacing the secondary belt
belt routing diagrams are sometimes on the underside of the running board [so when you are laying on your back, you can look up and see it, left side usually]. on a 46 inch deck, it's probable that the diagram is on the rear, center of the deck, you can see it by going behind the tractor, kneeling down and looking forward at the deck
Jul 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp mower with 46 in deck is making a "train whistle" sound periodically when mowing. the belts were new last year. I have lost my manual and don't know if there is too much play in the belt or...
Hey Jan..my name is Keith..and if your belts was replaced last year..i wouldnt suspect them of the noise...my guess would be that is something on the deck that needs lubricating..like a spindle..and this problem is hard to pin point from not being there...so..i hope this suggestion will help..if not please write back
Jul 11, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Drive belt
I don't have an answer for you, but Do you have a diagram of the Drive Belt?
Mar 14, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
189 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
