Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
Posted on May 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low pressure on hot water taps and showers
Hot water pressure very low , taps and showers only run as a trickle . Cold water runs as normal
  • bostock3 May 24, 2009
    the house is only five years old, have drained water tank and refilled .
    Pressure still low
  • Anonymous May 11, 2010
    New or old construction? New or old pipes? What kind of pipe? What kind of valves?
    If you've hooked a new water heater up to an existing system, especially if it's steel or "black iron" piping, odds are you have mineral deposits somewhere, or everywhere, in the line that are severely restricting flow. (running into that in my present abode) If you've double-checked and all of the valves on the hot water line are fully opened, the bad news is you'll need to replace the pipe.
    If it's and old heater, try flushing the water heater out through the drain at the bottom. If it's full of sediment, that may solve your problem for quite a while.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3165
Points
21
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
Anonymous
Level 2:
  • Expert 332 Answers
  • Posted on May 29, 2009
Anonymous
Expert
Level 2:
Answers
332
Questions
0
Helped
222673
Points
689
There are a couple of things that tis could be,. the cold water valve going into the heater could be bad or not open all the way or your plumber could have heated the connectin to hot and melted the tube, in which case you need to cut the hot side pipe back off take the adapter off and see if the plastic tube is either melted or has a ball of solder on it
1 Related Answer
Anonymous
  • 332 Answers
SOURCE: hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
Please help, water not hot in shower
If it is hot in the kitchen, then once the water has reached the shower it should be hot. The leads me to believe that the issue is with your shower mixer unit. Nearly all are thermostatically controlled.
Or, if the heater is downstairs and the bathroom is upstairs, you don't have enough hot water pressure. You need a good plumber with a pressure tester (called a manometer).
How can I increase the hot water pressure in my home?
Cold water pressure is what give you your hot water pressure so they should be equal but if you have a restriction on the hot side such as a valve not opening on the hot side or not opening all the way then you will have less pressure or the pipe work on the hot side is not proper. Hard to say but check the valve on top of the hot water heater
1helpful
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
6helpful
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
7answers
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
1helpful
2answers
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Hot water taps and showers pressure very low cold taps ok
3helpful
2answers
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
