Question about Rockford Fosgate Power T3002 Car Audio Amplifier
My amplifier is a t3002 keeps burning the fuses
I have a 900 watt punch that wont keep any fuse i put in it and need help badd! Its not my wirering cuz i have another amp in there now but its nothing even close to my baby!
Posted on Apr 13, 2010
Amp blowing fuses
Check for short circuit in speaker connections or the connecting wires unless some internal defect has occurred.
Apr 02, 2012 | Rockford Fosgate Power T3002 Car Audio...
Water spilled on rockford t3002 now protect light is on is amp repairable
All depends, when amp is connected does it blow the fuses, if not, it maybe repairable, But its a long process. when your amp is on and has water spilt onto it, the water inside the amp evaporates and gets into every nuck and cranny due to the amp heating up when powered on. you need to strip amp down to bare basics and completely dry the circuit board and all compnents one by one, hense a long process. Best thing to use is a hair dryer. get the hair dryer into every nuck and cranny, into the connectors, basically everything. once done. put back together and try it then. i had a home amp with water damage and fixed it this way.
Mar 03, 2011 | Rockford Fosgate Power T3002 Car Audio...
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
I have a t3002 going to a L7 12" sub. it played for bout 5 minutes down my road then no sound. the protect light is on. Y?
It could possibly be a bad ground. I ran in to the same problem the other day, but I wasn't driving. Started my car and everything seemed to work ok then all of sudden nothing. I checked all the voltages when the car is turned on, remote turn on (should have more than 11v), power cable to chassis ground (12+ V), they were all there. Then I finally checked the ground just moving the connection turned it on and then off. This occured repeatedly, then I disconnected the ground and then reconnected, now amp is running like a champ.
Oct 02, 2010 | Rockford Fosgate Power T3002 Car Audio...
Amp wont turn on and theres power to the amp and the fuses are good
check the ground to the amp. then check the remote wire. make sure u have the sub option on ur stereo turned on. if all is wired up correct an u do not have the subs turned on in ur stereo settings then the stereo will not send power through the remote wire an therfore your amp will not power on.
Apr 04, 2010 | Rockford Fosgate Power T3002 Car Audio...
My car Amp keeps blowing the main fuse, How to find the short?
Hello A4en1, hi, A short circuit need not be burned, the short usually are semiconductors such as ICs and transistors or diodes, I suggest you replace your IC power amplifier.
Mar 29, 2010 | Sony Car Audio & Video
Only thermal light on.
check rca and make sure u have right input to amp and speaker
Apr 12, 2009 | Rockford Fosgate Power T3002 Car Audio...
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
Rockford Fosgate Power T3002 Car Audio Amplifier Logo
243 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
