Question about Acer TravelMate 2303LCi Notebook
Bios not find hard disk
I have acer travelmate 4000 when power on my labtop start but did note found harddisk
  • Acer Master
  • 32,281 Answers
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
Posted on May 24, 2009
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
My laptop Acer TravelMate CL51-15 doen't start up. the message is ''no boot divice found'' and i can't open my bios for configuration
first of all, you must find a way to get in the BIOS. You can google search ACER TRAVELMATE CL51-15 BIOS updater. ensure that the laptop is connected to the charger befre you do any BIOS update. then you should be able to detect the hard drive and install you desired OS.
Jan 25, 2010 | Acer Computers & Internet
HOW CAN I RESTORE MY ACER TRAVELMATE 2200 without the original disk??????????????? NOW CAN U ANSWER THAT...ASAP
Hello !
Note: the recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook.
You can try ALT+F10 or CTRL+F10 during the initial boot cycle. This should prompt the laptop to access the recovery partition on the hard drive.
If it doesn't work :
Activate BIOS Setup Utility, press <F2> during POST.
Check the BIOS settings.
a Check to see if "Acer disc-to-disc" function is enabled or not.
b Make sure the [Acer D2D Recovery] setting in [Main] is
[Enabled].
c Exit the BIOS Setup Utility and save changes. The system will
reboot.
Hope this helps.
Sep 29, 2009 | Acer Travelmate 2200 Notebook
Acer travelmate 4000 hardisk problem
If the hard drive doesn't show up in BIOS either the drive is new to the unit, drive has failed or the motherboard may have a failed IDE/SATA.
If it's a new drive you're trying, go into bios and disable Fast/Quick Post/Boot from bios and restart the computer it should find it. If not either try a new drive you know works in the laptop or your drive in a laptop you know works and we'll figure it out from there.
Try these steps and let me know how it works out, if you can't get it narrowed down I'll offer a few more suggestions.
Chris
May 24, 2009 | IBM Computers & Internet
Black Screen
Check you BIOS settings and make sure that the hard drive is recognized in the BIOS. Also try clicking on reconfigure hardware settings and save and restart the PC. You might need to do a clean installation of the OS and this will require that you have a Windows Operating System Installation disk.
May 19, 2009 | Acer TravelMate 230X PC Notebook
Acer 8100 Travelmate - blank screen
Acer Ferrari 4000 "power on" blank screen, fan is running but no beeps, no activity in/from the HD. No reaction on a F8 start up (no Bios set up). It charges the battery OK.
KR Steen Larsen
Dec 08, 2008 | Acer Ferrari 4000 Notebook
Acer will not start travelmate 4000 series
does it pass the BIOS tests ?! if so, than u have to boot with a bootable cd to install the OS (new hard drive)
if it does not pass the BIOS tests, or gives errors, try reseting the BIOS, set it to the default settings ...
u can also recheck all connections (cdrom, mems, hard ....) and if the batteries pins have a good connection when pluged in the laptop...
give more details of what is wrong with it ... does the screen even get a image on it ... !?
Jan 23, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 2303LCi Notebook Logo
661 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
