Question about HP DesignJet 750c InkJet Printer
Help fix my HP750C, clear carriage path message
Having problems trouble shooting a clear carriage path turn swith off/on on a HP 750C 24" plotter I've tried lube on the rails, they did need it but did not work I've tried replacing the trailing cable, as the sensor read the encoder strip. Nothing that did not work. I've tried replacing the Y motor as I've read the CPA has driver rt and driver lt for "friction" etc. Anyway replacing the motor did not work. I have not replaced the encode strip, it looks perfect, no scratches, no marks, no wrenckles, nothing During inital power up the carrage travels to the left bumps and travels to the right, when it travels to the right it just runs into the paper cutter and displays the message "clear carriage path and switch off/on" It does it each time you power up
    Problem Solver:
  • 13 Answers
Sounds like it can not find home. Is there a limit switch? If not there may be a failure in the counter from the stepper motor.
Posted on May 24, 2009
Error 010032 00070b18
SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
070020 Is a drop detect sensor error, the sensor is part of the service station.
The check cartridge path indicates that the carriage rails need lubrication, use a light silicone or synthetic lubricant, (it could be other things, but this is the most likely), you also might need to replace the belt.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 08, 2014 | HP DesignJet 750c plus InkJet Printer
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5821600-carriage_jam_open_door_clear
Aug 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How can i clear carriage jam
http://www.fixya.com/support/t6088190-hp_7400_displays
Jun 08, 2010 | HP Officejet 4355 All-In-One InkJet...
Continue to get clear carriage jam after opening door and clearing or moving the carriage in hp 4215xi
Click here for instructions on resolving carriage jams on the 4215xi. If you successfully complete these instructions and still have carriage jams, your printer likely needs service.
I am an HP employee. I do not represent HP on this site.
May 26, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Everytime I turn on the designjet 750c plus, it tells me to turn power off and check cartridge path.
Make sure you have the correct cartridges and that the tape has been removed.
You can try a new set of cartridges and see if that solves your problem.
I hope this helps.
Have a good day and good luck.
Nov 20, 2009 | HP DesignJet 750c plus InkJet Printer
My 750C printer tells me to clear the cartridge path, I see no problem. How do I clear error message?
Your carrage belt probably needs replacing. Try and lubricate the shaft slightly with a drop of sewing machine oil. Look around either end of the belt where it goes around the motor on left side and tension pulley on left side, do you see a lot of purpleish bits/dust. If you do then the belt needs replacing.
Dave
May 13, 2009 | HP DesignJet 750c plus InkJet Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c InkJet Printer Logo
242 people viewed this question
Seeker5211
Seeker5211
