Question about Bose Wave Radio
I have a bose wave radio model# awr1g1
I need a fuse. where can i find it
    President:
  • Bose Master
  • 1,114 Answers
If It is infact a fuse, do you have the old one? If so either look in the yellow pages for an electronics supply house (not for an electrician) a repair house would do also. They stock more different styles, and values of fuses than you could possibly imagine. If none are local, google fuses. chances are not good that you will find what you are looking for at Home Depot or a gas station. Hope this helps. If you need more help, post again with the info from the fuse & I can help you find it
Posted on May 24, 2009
My four-wheel drive is blowing fuses I unplugged the trany the front axel and it still blows
What fuse's ? What all do the fuse's power ? Would need to look at a power distribution diagram ! Need fuse number ! Explain , 4X4 blowing fuse's .
T -case fuse #2 20 amp I/P fuse box , #4 gauges fuse 10 amp I/P fuse box Both of these power control module for 4X4 . 4WD fuse # 24 25 amp I/P fuse box .
Mar 18, 2017 | Chevrolet 1500 Cars & Trucks
How do I read all fuses without numbers to know what each individual fuse is connected to and what size fuse it uses?
You need an owners manual. If you can't find one. Go to alldatadiy.com and purchase the program for you car. It will have the fuse charts there.
Mar 15, 2015 | Lincoln Cars & Trucks
How do I replace fuse
Well you need to find where the fuse is located, And determine what type of fuse is being used. So you know what fuse you need to buy to replace it.
How do you know you need to replace the fuse?
Aug 30, 2014 | Microwave Ovens
Radio stopped working, need to replace fuse but owners manual is missing. Need to know which fuse is radio fuse.
Most fuse box covers have a diagram with fuse lableled so you know what they are full What outback is it I have a manual
Feb 17, 2014 | Subaru Outback Cars & Trucks
There is a fuse on the power supply board it says to only replace with ame fuse i understand that do i have to soder it out and in or is it more easily replaced.
hi there, if in case on your TV that the fuse is needed to solder out before it can be removed, yes you need to solder it out. But if it has this fuse terminals that you only need to tap it out better if thats the case. Some TV has this fuse terminal for easy access in replacing the fuse. if still needed to solder the fuse I suggest that do a little rewiring and put a fuse holder if available, if just solder the new fuse as is the same as the old one. hope this help, please rate and vote. good day
Apr 03, 2011 | Televison & Video
I need to know if i need a new headlight switch or if i need a fuse replaced, but i need a diagram of the fuse panel.
The fuse block on all models is located under the left hand side of the instrument panel. All flashers are mounted on the fuse block. Each fuse is marked on the fuse block as to which circuit it is protecting. Some early models also use an in-line 30 amp, fuse for the air conditioning hi-blower, located at the cowl relay and an in-line 10 amp, fuse for power antennas.
Check this diagrams...
Fig. 19: Chassis wiring - 1981-83 Cutlass
Fig. 20: Chassis wiring - 1981-83 Cutlass continued
Hope this help.
Mar 11, 2010 | 1983 Oldsmobile Cutlass Supreme
How to get to underdash fuses of a toyota matrix
The 15 amp dome fuse is in the fuse box under the hood and the 15 amp CIG fuse is in the lower finish panel up under the dash on the drivers side. These are needed for the radio. The above fuses plus the 15 amp Gauge fuse in the box with the dome fuse under the hood are needed for the clock.
If the clock is the only defective module, I have removal instructions and a repair service. Check out www.autoclockrepair.com
May 08, 2009 | 2005 Toyota Matrix
Need # of amps of fuse for Wurlitzer 4100 Series organ
That means it is 1/8th Amp fuse. So the info you have is the fuse you need.
The other fuse (mains) is a 5 Amp
Apr 23, 2009 | Audio Players & Recorders
Need to know fuse numbers
number 32 is the front cigarette lighter fuse 2 and 27 for the audio unit which i presume means radio
these are in the fuse panel under the dash on the drivers side
Feb 26, 2009 | 2002 Lincoln LS
Bose Wave Radio Logo
446 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
