Question about GE 27" Built-In Double Electric Convection Wall Oven - White-on-White
Door and trim replacement for built-in oven?
I have a built-in GE double oven with white exterior. I want to upgrade to stainless steel. Is it possible to replace the exterior components only (door and trim) in stainless steel? There is nothing wrong with either oven, so it doesn't make sense to replace the whole thing just for 'looks'.
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Posted on Jan 17, 2009
  • 1891 Answers
SOURCE: i would like to replace the white doors with new
changing them is easy the cost is very high .. you can purchase them from any parts supply / . the problem is if the doors are white so is the control panel / most stainless doors units come with blk control panels . this is a very costley adventure . **** hope this helped ..
Posted on Jul 15, 2010
  • 246 Answers
SOURCE: I have a 10 year old GE profile dbl wall oven that
Go to www.applianceart.com and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
Posted on Nov 02, 2011
  • 246 Answers
SOURCE: GE DOUBLE OVEN MODEL K25003DC
Go to www.applianceart.com and check out their instant stainless material for refacing your existing doors and getting the stainless look you desire.
These guys can assist you with the whole process. Worth checking out.
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
I HAVE A DOUBLE OVEN GE MODEL JKP55DPEWW WHITE AND WANT TO REPLACE THE DOOR WITH STAINLESS STEEL,PLEASE HELP
When I removed the front cover there were other color door fronts stored in side. I would just order a SS door front from a dealer or parts supply house
Apr 30, 2014 | Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
Oven light doesnot turn off
HI, This will be a simple fix here. The light switch will be the culprit. The circuit is damaged, thus, allowing for a continuously closed circuit. Simply replacing the switch will solve this issue. The switch should be mounted on the control panel. remove the control panel front trim screws, to access the switch housing.
Nov 22, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Oct 18, 2009 | GE Profile JTP56 Electric Double Oven
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Jul 29, 2008 | GE Profile JTP56 Electric Double Oven
GE 27" Built-In Double Electric Convection Wall Oven - White-on-White Logo
549 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
