Question about Technics SL-1210 Turntable
Deck fades out when i bring the second deck in (records I mean)
Hi. I have got a pair of Technics 1210 mark 2 dekcs, a Gemini PS626x mixer and a standard amplifier. I have had them set uo for over a year and they have worked beautifully. When I moved house I could not set them up for about three months so they sat safe on the floor, un-touched. I've now set them up and when I am mixing a record from the left deck to the right deck, as soon as I bring in the second record on the right deck, the left record fades out and then back in again. This also happens when the record is playing on its own and I am bringing nothing in from the right deck? I am confused. Please can you offer any advise. Thank you
  • 104 Answers
Are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
Posted on May 26, 2009
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
Hi there, i just bought 2 Technics mkii
well" for a start, they need to go into a phono socket, this amplifies them.
i take it you bought 2 decks with the intentions of mixing, so you gonna need a mixer.
MIXER & DECKS SET UP:
1.decks into phono channels 1&2
2. black GROUND wires, go to GND screw on back of mixer
3. RCA master / booth Outputs on mixer to AUX / LINE-IN on amp.(not phono)
Oct 09, 2013 | Technics SL-1210 Turntable
1210 mk5 poor sound
If the cartridge is good and your wiring is good. Then it's either got to be a fault on your amp, or there is a pre-amp in the deck itself faulty. Double check that the amp is working, amps have a pre-amp for record decks, they cause trouble a lot.
If you touch the wires that connect to the cartridge, you should get a buzz on either channel (remove them from the cartridge first). If you don't get a decent buzz, and you know that the amp is working fine, then there's something inside the deck causing the problem. In which case take the bottom off and take a look inside.
Feb 11, 2010 | Technics SL-1210MK5 Turntable
How do i free up the tononig arm on a technics 1210 deck? It is stiff and wont move across the record.
It should really be replaced but you can try adjusting the screw on the top of the arm
Dec 23, 2009 | Technics SL-1210 Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Channels
Could be one of 3 issues:
1) Tonearm
2) RCA Cables
3) Cartridge/Styli
I generally tell people to try different cartridges first. If that doesn't work, then you know it's either your tonearm or your RCA cables. 80% of the time, it's the RCA cables. It's very hard to determine which one it is at this point without opening her up and putting on some new RCA cables to test. If it works, then your good. If not, then you know it's your tonearm, and will need to be replaced.
- DJPROLAB
Feb 13, 2008 | Technics SL-1210 Turntable
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
94 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
