Question about Danby DPAC8020 Air Conditioner
Iceing up my unit not cooling properly and it ices up by the filter
    Problem Solver:
  • 14 Answers
Either its dirty, or it has a coolant leak. Try to clean the fins out really good. If that doesnt work, call in a pro.
Posted on May 24, 2009
Behind the filter on the coils it is iceing up
Be sure blower is running and coil and filter are clean. Ice is from a refrigerant leak, it needs refrigerant
Jun 17, 2017 | Filter Heating & Cooling
Refrig. dose not get cold and the freezer is iceing up
It has a defrost issue and there is too much ice built up on evaporator and the unit does not have proper air flow.
Refrigerator Wont Get Cold But Freezer Will
Jun 02, 2014 | Refrigerators
Carrier heat pump iceing I replace defrost bord 3 days good works but now iceing again
Air flow
Feb 03, 2013 | Heating & Cooling
2000 ford explorer air cinditioning blowing low cool air added freon clutch working properly condenser is not iceing, but sweating still no changein cooling. not cold air, but low cool air, why is this...
If you attempted to add to the system, you most likely
added some air into it also
Unless you have a vacuum pump & can leak test,
evacuate the system & recharge yourself,you will
have to pay someone to fix things
Jul 04, 2012 | 2000 Ford Explorer
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
Pipes iceing up and not cooling house
you need to call atech to come out and check your unit twomany thing to list could be wrong
Sep 02, 2010 | Goodman Heating & Cooling
Unit iceing uo
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 04, 2010 | Kenmore 54501 Dehumidifier
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Condencing unit
Check filters to see if dirty, clean or replace. Is the coil or condensing unit iceing up? If so, have your system recharged and checked for leaks.
Jul 03, 2008 | Goodman GMS90703BXA Heater
Goodman CKL60-1L
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
May 20, 2008 | Goodman CKL60AR60 Air Conditioner
Danby DPAC8020 Air Conditioner Logo
64 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
