Question about HP W19b LCD Monitor
HP W19B monitor displays menu all the time
Without touching, the menu display "pops" up
  • HP Master
  • 3,866 Answers
There is a little circuit board under the buttons that has gone bad or the button was pushed to far in and depressed the button sensor inside, befor you begen going into this monitor let me warn you of the risk. There is very high voltages inside that can ;ead to injury up including your death, so with that in mind and your ready to pop the back off this, lok at the little board take a cue tip, cotten swab and genly push on the button to see if it free itself if not this little board will need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 24, 2009
  • 4line Sep 26, 2010
    I had a similar problem I locked out the on screen menu and it has gone way. You might want to give it a try for your self. turn the monitor off. Press and hold the menu button. Turn the monitor back on while still depressing the menu button. This will lock the menu. To unlock it go through the same procedure.
How do i change the language on my hp MX308
HI,
Follow these steps to reset the language and region on the product.
  1. On the product control panel, touch Setup. The Setup menu displays.
  2. Preferences . The Preferences menu displays.
  3. From the Preferences menu, touch Set Country/Region . The Set Country/Region menu displays.
  4. From the Set Country/Region menu, touch and then slide your finger up or down on the display to scroll through the list of countries, and then touch the desired country/region. The Preferences menu displays again.
  5. From the Preferences menu, touch Set Language . The Set Language menu displays.
  6. From the Set Language menu, touch and then slide your finger up or down on the display to scroll through the list of languages, and then touch the desired language. The home screen displays in the new language.
Thanks,
HP Printer Support
Jul 14, 2014 | HP Photosmart C4280 Aio Printer
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
Osd locked message from HP in on for the first time. What is osd and how do I get rid of it?
When the OSD is locked, settings cannot be changed in the OSD menu. To Unlock the OSD, press and hold the MENU button on monitor while the monitor is off, then press the Power button to turn the monitor on. To lock the OSD, repeat the Unlocking procedure.
Mar 17, 2010 | HP W19b LCD Monitor
Does it have speakers and haw to turn them on
as shown form the pictrure from hp it seems it has. check if you conected the jack in your computer and monitor. start the menu of the monitor using the buttons on it and try to get something like sound. if this doesn't help test each button of the monitor to see. they may have separate functions than the ones from the menu
Jan 25, 2010 | HP W19b LCD Monitor
Monitor has green light but nothing is displayed.
Try Checking The Video Plug In on The Back Of The Tower(or modem.)
Sep 28, 2009 | HP W19b LCD Monitor
Hp w19b monitor is not in focus, how can i fix it?
press your Menu Butten and go to set resulution and set your monitor Focus.
Jul 31, 2009 | HP W19b LCD Monitor
HP w19 display is messed up in many ways!
I am wondering if the monitor is close to some other electrical device like a TV. Try hitting the degausing button if it has one. This is like a monitor reset button and removes stray magnetic forces from the monitor.
most monitors do have them amongst their array of buttons or on the rear might also be a pinhole, but be carful incase you touch a live wire
Jun 23, 2009 | HP W19b LCD Monitor
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Fuzzy, shadowy LCD monitor warranty
Occasionally the cuplrit to a shadowy haze on an lcd monitor is the VGA cable. A new one that is better shielded may help.
Jan 25, 2008 | Gateway FPD2275W LCD Monitor
Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Jun 14, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
HP W19b LCD Monitor Logo
1,062 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
