Question about Fuji FinePix S5700 Digital Camera
Lcd screen problem
When i switch my finepix s5700 camera on the lcd screen is white with lines through it, everything else is ok .it still takes photos
  • 6,784 Answers
HI, this is isolated within the LCD screen. the input ribbon may be defective or, the entire screen could also be damaged. you will have to replace the lcd screen in this case due to the integrated design. you can confirm my diagnosis by, pulling the battery or plug for 5 minutes. if this screen is still not operating normally after you re insert the battery, this will confirm LCD screen failure.
Posted on May 24, 2009
My fujiflim finepix s5700 is broke the main lcd screen has white lines with strips i have not dropped or damaged it please can someone help me
Unfortunately this is not a user repairable problem. Either you LCD screen is failing or the ribbon cable connection is not good. Both are not repairable by the consumer.
May 03, 2011 | Fuji FinePix S5700 Digital Camera
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
MY finepix s5000 fujifilm camera has a white screen displaying when i turn it on, is there anyways i can fix that problem with out haveing to take it in.
Had the same problem with my s5700, white screen, took it apart. two screws on the left (facing the screen) under the strap, two in the usb compartment, two (screen side) screws on the bottom, three screw in the battery compartment, and the final just below the right side strap. Carefully pull the back off and check the ribbon connection from the lcd to the board. push it in made sure its seated. Reasemble being careful not to bend the ribbon connectors. Worked for me.
Aug 05, 2010 | Fuji FinePix S5000 Digital Camera
When i try to use the screen display a get a blank white screen with a series of straight vertical lines on the left hand-side of the LCD Screen as well as one staright horizontal line going across the...
Sounds like your LCD screen might be broken. Try PhotoTech Repair in NYC. They are manufacturer authorized to do repairs.
Here is the website:
www.phototech.com
Mar 29, 2010 | Fuji FinePix S5700 Digital Camera
Fuji finepix s5700-- LCD not working
your lcd is cracked internally. repair is not usually economical than to purchase new unit.
Jun 01, 2009 | Cameras
FinePix S5700 LCD Screen Problem
you need to send it to fujifilm for repair. i dont think its too expensive at all. this is a common problem with many cameras
Apr 14, 2017 | Fuji FinePix S5700 Digital Camera
Have changed my camera to take black and white photos but need to take colour photos again - fujifilm finepix S5700
Turn the camera on. press "F" button to select F-MODE. Use menu button to scroll down to finepix color. Select STD (standard)
Jan 03, 2009 | Fuji FinePix S5700 Digital Camera
Colour tone issues with Fujifilm Finepix S5700
It sounds like the sepia tone is most likely caused by the tungsten lights in a regular room. Without flash, the only source of illumination indoors is artificial light (unless window light is dominant). There is a way to color balance the camera to approximate sunlight through the manual settings. Look in the menus for "white balance". You'll need to take the camera off of the fully automatic settings first. Move the cursor up or down while looking at the image and you will see the color shift. when you find a color balance you like for that particular room's lighting conditions, hit the OK to lock it in the activated position. Remember to go back to "auto" white balance for most shooting, especially outdoors, or everything will take on a wierd color cast.
Jun 03, 2008 | Cameras
FinePix A340....Flashing lines across LCD screen
I have the exact same problem !!! I wish someone would be able to help with this one !
Mar 25, 2008 | Fuji FinePix A340 Digital Camera
Fuji FinePix S5700 Digital Camera Logo
382 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
