Question about Frigidaire FAX054P7A Wall/Window Air Conditioner
Bad Odor When the Cold Air Stops Blowing
The unit works great. It's a couple years old. However, when the cold air kicks off as it reaches the right temp, it emits a terrible smell. I've read alot about the drip tray or something having to do with the water being plugged. I cannot figure out how to get to it and their website manuals are not linking right so I can check which screws I need to take out to get to the problem. How can I resolve this odor issue? It's unbearable.
  • jessicadrago May 25, 2009
    I'm sorry. This is a window unit. It's a Frigidaire FAX054P7A
I had a similar problem with an 8,000 BTU room air conditioner. I originally thought the cause of the smell was a rubber gasket, but after opening the unit up I found that it was just dirt (plus what seemed like 100s of dead bugs in various states of decomposition). I carefully removed as many screws as I could to get at the bottom tray, which I scraped with a flat head screwdriver and wiped with a rag. I ultimately found that the biggest source of the odor was the outside condenser coils, which I proceeded to squirt down with a garden hose. The entire process took 2.5 hours and definitely was a pain, but at least now I can run the unit without gagging on the smell.
Posted on Jul 07, 2010
    President:
  • 3,433 Answers
Is this your car or house a/c?
Posted on May 24, 2009
  • Ned C Cook
    Ned C Cook May 25, 2009
    Many times when a wall or window a/c unit is installed the installer levels the unit.It should actually be lower on the outside end than the wall end. This keeps the condensate water from collecting in the pan waiting to evaporate.. There ishould be drain Hole or knock out at the condensor end of the pan. The condensor is the radiator looking thing outside. If nno hole can be found , one can be made but with extreme caution. A drill will puncture the condenser if it even bumps it..It is better and safer to remove the unit or at lest slide it forward out of the cabinet befor drilling. Thats the cabinet, now the pan needs a hole . making really no difference where as long as its away from anything the drill would damage. Once the water drains its a mater of keeping the filter clean. Household dirt and such really stinks when damp and the evaporator the filter covers is always damp.. Good luck and Make sure it drains into an area water won't cause damage.
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
The other night my ac unit started making random clicking noise and now it is not blowing cold air, it blows room temperature air. I keep the front vent clean. it is an LG window unit.
how old is it there are capacitors that controll the fan and the compressor and if it goes bad the condensor will not kick on or the condensor could be bad you say its blowing air so rule out the fan side and look at the condensor it could be one of the two remember capacitors are high voltage batteries and shoul be properly drained with a resistor and tested with a meter before removing it doesnt have high amperage but it does contain high voltage great risk of shock please be very carefull working around them and with any electric device un plugg before working on
Jul 31, 2011 | Heating & Cooling
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Jun 07, 2009 | Whirlpool ACQ189XM Air Conditioner
1998 Oldsmobile Silhouette. After driving more than 50 miles the a/c stops blowing. When it does work it is cold
The system may need to be recharged, All A/C system will have small leaks though the seals and when you lose enough R134 the system will stop blowing cold air. I am guessing that it stop working now as to that there is no cold air but the blower fan is still working right?? Or do you mean that there is cold air and then it stops making cold air after 50 miles but will work again after a few hours of the can not running. If that's the case, the A/C relay may be bad and when it heats up the relay fails and needs to be replaced. Good luck and keep me posted.
Jun 03, 2009 | 1998 Oldsmobile Silhouette
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Frigidaire FAX054P7A Wall/Window Air Conditioner Logo
738 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
