Question about Amana 3.2 cu. ft. Top-Load Washer
Washer wont drain
My admiral washer LNC6766B71 will only drain if i lower drain tube to the floor
    President:
  • 1,136 Answers
HI, Does the motor run while in the drain cycle? With the wjater out of the washer, tip it back against the wall and see if the belt is ok. You can also remove the belt and try turning the pulley on the pump (located in the rear right corner) with your hand
If the belt is on and the motor runs, the pump is probably going bad.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 24, 2009
I have a admiral washing maching, model LNC6766B71, it is top load. It makes a load noise in spin mode.
if noise is constant maybe bearings? Is the load even? Not totally familiar with item but the I think the two possibilities above are worth considering. Do an spin on empty. NOISE??? I would guess bearings.
Jan 02, 2016 | Admiral Washing Machines
There is cloth stuck under the aggitator on my Capacity plus Admiral washing machine. Model #lnc6766B71 how do I remove the aggitator
As a general rule Admiral is a VERY inexpensive machine, so you may be better off with a new one if the parts prove expensive. MAKE SURE TO UNPLUG MACHINE.. Be careful the agitator doesn't come loose suddenly when you are removing it, I have seen more than one bruise on the face from this.. hold your head to the side when pulling it off. http://www.rakerappliancerepair.com/NephewClub/Diagnostics/Washers/Maytag/Maytag%20TL%20Bulletin%20TDL-0086-B.pdf
Jul 06, 2015 | Admiral Washing Machines
Water wont stop draining when in wash cycle
In the front load washer is use the drain pump to drian out the water. so the water out tube (pipe) was hang up hihtger them to washer tube. your machines problem I thinh it is the drain out tube (pipe) was fall down lower them the washer tube.please correct it.
Jul 11, 2011 | Washing Machines
The freezer side of my admiral leaks (collects water and it freezes) at the bottowm. then leaks to the floor. what can I do to fix it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Oct 29, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice in freezer bottom
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | Admiral Refrigerators
Water is left in the bottom of the dishwasher after the cycle is done
Sounds like a partial blockage in the drain-check drain tube and drain it plugs into. Could try disconnecting drain tube from sink drain and lower it close to floor level into shallow pan. I excess water come out slowly blockage prob. in tube or filter screen in washer.
Oct 09, 2009 | Dishwashers
Admiral Top Load Washer Model LNC6762B71 overflowed
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Feb 28, 2009 | Admiral AW22 Top Load Washer
Admiral heavy duty washer - cleaning filter
Aw22 doesn't have one, remove the front panel to gain access to the pump, To do this insery a flat knife between the top panel and the front panel 4" in from each side to release the clips.
Unclip the two hoses to the pump after draining the machine, lower the external waste hose to floor level to drain.
tilt the machine back to remove the belt.
Remove the 3 bolts for the pump to remove and clean out.
refit in reverse order.
Jun 05, 2008 | Admiral AW22 Top Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Admiral washer
Check from where does the water come? From the bottom of the machine or from the the drain plumbing tubing?
Nov 15, 2007 | Washing Machines
Amana 3.2 cu. ft. Top-Load Washer Logo
102 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
