Question about Dell Dimension 3100 PC Desktop
Why does my curor freeze up?
My mouse occasionally freezes on screen and I have to reboot to get it back. Usually freezes after 5 - 10 minutes of use. I reinstalled the driver, placed the mouse USB connector in another port, opened up the case and cleaned every piece of dust in case it was overheating. Nothing else freezes up as I can still use the keyboard to navigate (poorly haha)
  • Chris
    Chris May 11, 2010
    Given the steps you've taken it sounds like the mouse itself or the USB hub you're attached to may be at fault.
    Each USB hub generally has two ports in a pair, if the USB port you moved the mouse into is in the same pair, try moving it to a different pair and try again. If that doesn't work or you already tried a different pair I would suggest trying a different mouse.
    Sergeant:
    Champion:
  • 212 Answers
First I would replace the batteries. I had the same problem a couple of years ago. The solution for me was getting rid of McAfee AV. To check if it is your problem, use CTL-ALT DEL to turn McAfee off and see if that gets rid of your mouse freeze ups.
Posted on May 24, 2009
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Pc touch screen freezes
LOL, I would never buy a touch screen. Give me a mouse, it's so much easier to replace a $10 mouse than a $400 touch screen.
Apr 15, 2012 | Computers & Internet
Mouse freezes
If it is wireless try putting in some new batteries and moving the receiver to a different USB port. You could also try moving or disabling any other wireless equipment nearby to see if that could be causing it.
If it is a wired mouse try a different USB port, making sure it is plugged in directly rather than into a USB hub, re-installing the driver and rebooting the PC. With more information I could help further.
Jun 03, 2010 | Macally dotMouse (DOTMOUSEMM)
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
Mouse occasionally freezes
thats a laser mouse so its not ur mouse the problem, it is ur internet connection, try not to download anything while playin games online and hopefully it wont freeze that often, hopefully this helps U. :)
Feb 11, 2008 | Logitech MX 400 (931638-0403)
Dell Dimension 3100 PC Desktop Logo
335 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
