Question about Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
No moisture moniture light and does not dry completely.
  • Maytag Master
  • 3,361 Answers
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
Posted on May 24, 2009
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to install moisture sensor bar on Maytag Neptune
I do not recognize that part number but an exploded diagram for the dry is at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833
Click on the tumbler diagram.
Mar 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Moisture in my dryer
moisture in tha dryer is definatly an issue with not being able to vent out the moist ais from drying the clothes, did you check where the vent exits the home?, the only way moisture collects in a dryer is by not properly venting it out...
Nov 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Moisture sensing strip coming off
it can work on timed dry with out the strips. they are only in use during auto dry cycle
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
425 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
